- 3,212
- 376
- 83
- Tonopah, AZ
I noticed that I have a rear axle leaking. I took the hub apart and I had gear oil in with the bearing grease and leaking on to the inter wheel.
I looked at all the seals and they looked ok. The little cork key-way looked ok also.
Is RTV the way to go and not use the cork seal or the outer hub paper gasket?
Is there anything more I need to be looking for?
Have seals on order.
Thanks!![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
Thanks!
