mikey
- 39
- 28
- Lake Como, PA
I have been searching the TM's for literally three hours and searched SS as well but need some help.
I need to change the tranny fluid in one of my deuces which was topless for years. She spits steam so I'm confident it's got some water.
I cannot find a TM that explains the process. I find TM's that break the transmission down piece by piece and I can pretty much rebuild one, the lo TM shows me the drain plug and filler plug as well as the oil to use and capacity, the maintenance TM's show me how to check the transmission housing, but no TM to describe the process of actually changing the fluid. Does the process exist in a TM? If not, is it as simple as remove the drain plug, drain fluid, replace drain plug, remove filler plug, fill to one knuckle length of index finger, replace filler plug?
Are there any washers, gaskets or anything I need to replace? Any torque values I need to consider?
If the TM exists, please direct me to it. I'd also like to know how to change the fluid in the transfer case.
Thanks
Mikey
Thanks
Mikey
