Alt belt sguil
REDWOLF
Risingsun Maryland
Does anyone eles have the problem with the passenger side alt belt not staying tight and squiling at start up? I have titened that thing to many times to count and after a cpl days it statrs all over again. Only at start up and only if i am in a hurry and do not let the truck warm up a bit. :roll:
kdaniels
Dothan, Al
Mine does the same thing on startup...and after 6 yrs it still is a source of irritation. Someone eles on the forum has brought this topic up before and i believe the solution is changing to a higher quality belt. Do a quick search and i'm sure those belt #'s will be available if you choose to swap'em out.
SEMPER FI !
keith
lavarok
33
Fellsmere, FL
Sometimes it helps to have a helper when tightening the power steering pump in place. I like to use a pry bar from underneath and have my son tighten the bolts from above. Goodyear gatorbacks also help.
K9Vic
Fort Worth, TX
Wrong side, but yes that is a PITA to tighten right by yourself a helper is best. My driver side is still slightly loose and needs to be tightened down again.
lavarok
33
Fellsmere, FL
:doh:
wow..completely misread that post! Yikes....I need more coffee.
EDIT:
If the alt keeps coming loose, the bolt hole in the alt is stripped OR the bolt threads are rolled.
I had this happen to me last month in my '08 . It lost the belt to the fan, which then proceeded to tear up my other two belts. I ended up getting a different bolt and cut some new threads. It may have just fixed the original threads, but either way it stays tight now.
