jbeachmba
- 0
- 0
- Forest, Ohio
Is it possible for engine oil to get into the air supply of the Deuce?
I have a NEW small oil leak that comes out of the flywheel housing that has only recently started. I think is from the rear main seal but is manageable at this time and considered "marking my territory" size leak.
This causes oil to be blown back under the truck when driving it and it is possible to get oil on the blow off valves on the accumulator tanks. But it appears to me that the oil is in the tank.
I can not think of how the oil could get into the air system.
Do any of you know if oil can get in the air system and what could be causing it?
