kipman
- 15
- 38
- Lancaster Ohio
What I mean is you remove the injector, unscrew the cap, and put in the new parts, no need to replace the whole thing.
Hopefully the pic below will help, while it is not a 6.2 injector. The intermediate plate and the nozzle below will mate together, if they are not flat they will leak. The tech will run them on a lapping plate to insure both are flat. Hope this helps. The plate is circled in blue and the nozzle is below.I dont know what " lap all the mating surfaces" means....
6.5 injector "most " are calibrated for the DB4 pump not the DB2, you may get into some ineffective fueling issue and pump adjustment issues. I belive the 6.5 injector has a larger opening ect..I dont know what " lap all the mating surfaces" means... I keep reading about Marine injectors. I read apost about buying the marine tips for a 6.5l ...but then i read someone else said they dont fit so he bought 6.5l Marine injectors with a fine thread and was installing them. but the thread left off and didnt get a report on performance....
Anyway getting ready to take her out on the xway I will let you know if my sea monkey foam fixes my injectors.
Did you check the propper setting of the IP. There is a mark in the housing and a mark on the IP fange. These two markings MUST be perfect in line.
That solenoid is the on/off solenoid.Ok Im messing with my truck today... I got the top off the Injector pump. There is a gizmo on the lid that has a black seinoid that the pink wire conects to...I think. The O ring around the inside had some crud on it. Im sure it is from me putting Veggie oil in my system. Im going to turn up the screw a 1/4 turn, If I can I am going to advance the timing a little.
What does this plunger do???
Ok I just put it back together, took her for a test drive...so i can feel the extra power... Now I notice a little "surging" Air in the the system maybe?
