4x4e350
- 5
- 18
- Vestaburg, Mi.
I was checking the fluid condition and levels on the 5 ton yesterday, all three axles look like the fluid was just changed, good news!
Anyway, as I removed the plugs on the axles, all three axles released pressure as I was turning the plug out. It wasn't just a little amount, it seemed to be atleast a few psi. I would'nt of thought much about it, but it just seemed odd to me that all axles had the pressure.
All my axle vents are just the little nipples with a cap on top, so no hoses or special fording kit. Do the axle vents have some type of check valve, so they wont release pressure till a certain amount of psi is built up? Or should I remove all the vents, and make sure they aren't plugged?
