12v headlamps in a deuce
ICAT
Idaho
Has anyone figered out a way to use 12v headlamps in a deuce without rewiring the truck. I was thinking about resistors or a reostat the get it down to 12v. I can't find a headlamp under $50.00 bucks.
Squirt-Truck
Master Chief
164
Marietta, Georgia
Why??
Wire them is series and you can run 12v lamps.
Why??
Saturn has headlamps for $26.50, e-pay has them for less.
Why??
H4's are available in 24v also.....
Jinx
Buy me a Coke
753
203
Gainesville, FL
Why??
Why??
Saturn has headlamos for $26.50, e-pay has them for less.
Why??
I REALLY wouldn't recommend wiring headlights in series. One bulb burns out during the night and suddenly you have no headlights at all!
rlwm211
19
Guilford, NY
If you must....Install an Invertor inline with the power feed to the dimmer switch and then switch the bulbs to 12 volts. The light switch will not know the difference and the only other change you need make is the harness connector to the bulbs themselves.
RL
ICAT
Idaho
my hope was to keep the price as low as possible. With the venders and fleebay the price is still around 50 bucks. I just thought someone might have already came up with a workable solution to use a 12 volt light. I am taking in all suggestions.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
Well, you could run 2 bulbs per side in series and get them working. You could also step up to LEDS, spend your kids college fund and never buy headlights again or just spend a few extra bucks here and there over the course of the MVs lifetime.
D
Deleted member 11142
Guest
dont drive when its dark and you'll never need to get new lights!
hoop
14
va
7" Round...28.99 free shipping.
H4 light....5.00 each 5.00 shipping.
Pig Tail....6.00? each.
Less than 60.00 for 2.
doghead
4 Star General /Moderator
1,193
A simple Google search for 24 volt headlight, will get you results. The very first listing has them for $30.
A little effort goes a long ways....
ICAT
Idaho
yes it is $30.00 but when you add in shipping i might as well to the parts store and pay the $50.00. I'm just looking at all possibilites. I'm a school teacher so I have to watch every penny.
319
Lieutenant
3,347
58
Michigan
Why mess with a good system? Bite the bullet and buy the military headlamps. This way you won't have to spend extra cash and time converting to 12 volts, or worse yet, troubleshooting when a problem arises.
Headlight, 24 Volt, Sealed Beam w/ Rubber Shell Connectors, 8741491 / 4863-1 / GE 4860
Also, do the lamps from the parts store have the military pigtails?
Good luck.
ICAT
Idaho
some have the pig tails and some just have the 3 prongs. i can reuse the three ends off of the old light. yes if i have to i'll buy the mil light just weighting options which seem to be very few
Clay James
Reno/NV
My M109A3 did that to me a few times when I would switch between high and low beams, pretty scary. Luckily when I hit the switch again they came back on. I suspect its the dimmer switch.
doghead
1,193
Where did you order from, and how much do they cost?
