SteveKuhn
- 4
- 0
- Hasbrouck Heights NJ
The lunette on my trailer is bent to the passenger side. After taking it apart, I discovered that not only the front vertical bar to the brake actuator is bent, but also the top transverse pin (see highlights on attached TM drawing.) I have doubts whether any of the bent parts can be straightened out satisfactorily.
Even with the bent bar off, the lunette will snap back into that sideways position if you use a bar to angle it straight. I suspect all pins and at least that 1 bar will need to be replaced.
I've highlighted the TM drawing with the parts I've identified so far (bar = 3; pin = 5).
I'd like to repair with standard parts but I'm having trouble finding a source via the Internet for either these bent parts or the larger assembly. I'd appreciate hearing of likely sources.
I'm also considering having the bar (3) fabricated and replacing the pins (5) with same-size grade 8 bolts. Would appreciate comments on that idea or any others someone might have.
Thanks.
SK
Thanks.
SK
