AMX
- 3
- 0
- Walland tn.
After a couple hundred miles my air pressure buzzer would activate. The problem was this regulator mounted on the left front inner frame rail. After removing the protective aluminum cover i found the end of the plastic housing had broken off leaving a direct air opening. I simply replaced the regulator with an old one I already had, problem solved.Hopefully these pictures will help if any of you ever encounter this problem.
