In the future when adding electrical accessories to my truck I will be using this set up. Right now its only rigged for 12V but I will be adding an identical fuse/distribution block for 24V use. This is the simplest way I figure, its how boats are done (these are boat products). I love how MV's utilize fuses - not! I can do electrical but I still am not totally filled in on the electrical protection in these trucks. I know that there are some sort of breakers that self reset? Any way I don't want to try and mess around with whats already under the dash - spagetti - so this is my solution. A 24V fuse/distribution block can be mounted most anywhere and all you have to do is pull a + and - wire of the last battery (dag simple). The shiny rectangle box in the pic is a 24v to 12v 25 amp converter which is fed from the top battery switch which is fed thry a fuse from the MAIN bottom battery switch. This is to isolate the 12v system. The converter's output then goes to a single 12v battery under the seat and then the + and - from that feed the 12v fuse/distribution block. The battery under the seat is grounded to the ground of the main truck battery set. The converter is more than capable to power the two 100w KC's seen in the second picture. The HD battery switches are what I have mentioned before about a secret kill switch. These are the Blue Sea switches from West Marine but come in red off the shelf, if you want the black they will have to special order them. Just my 2 c' but I don't want to limit myself to one "Y" under the dash to power more than one item. Hope this helps someone.
