EODTECH90
- 0
- 0
- Hinesville,GA
yea, i got it from GL and its in the can so the plan is to start it in there
rcovery you are amazing , i didnt think of the race car thing, im gonna have to find one, groundhop, that makes sense it is after all already secured in there makes sense thank got for the 10 ton crane i can use otherwise this wouldnt be possible, if you can come out here i could meet you halfway, i need someone with more cucv knowlage than i on siteGroundhop, starting outside the truck. Wish I could get up there, always collecting 6.2 parts.
Ryan77, it's not quite that easy. The heads are unique to this engine. The bolts holding the intake are at quite a different angle. In order to use a regular N/A or turbo intake will require a head change.
EOD, I would look into some race car fab places. Once you get the engine in maybe they can make a cover for the inside that attaches with dzus fasteners so you can remove it for service.
No we never thought about taking pics just getting it done we had a deadline.do you have pics??
To swap a side mount turbo onto a trcuk with a center mount requires you ue NA or side mounts heads as well. The heads on the center mount were different.Go to the bone yard just get the turbo, etc it will be a heck of a lot easier and cheaper! use your good block!! Just my 2 cents ive done the swap your talking about!!!
