Jersey4x4
- 1
- 0
- Absecon, NJ
Does anyone know where to get replacement fuel tank straps for the primary and secondary fuel tanks? Prefer new but used good is fine also.
I have been making my own from sheet metal. Just have your local shear some sheet metal at the width and make it plenty long. Use an angle grinder with a cutoff wheel to make a slot inthe end that you have folded about two inches back from the end. I then cut the hexhead off a 5/26 x 2 1/2 bolt and weld a tee tothe top . You now have the start point no need to weld the end closed since the bolt will not pull through the slo. I put the open end on the inside. measure it up to the original or wrap it around the tank to be strapped and you hav ethe overall length. Repeat step one for the other end and you will have the same strap that was made at the factory. for a fraction of the cost of a new one.
