OK, wow, first attempt at bleeding was another humbling experience. This is supposed to be easy with a pressure bleeder, huh? Here are the 2 main issues I'm having:
1. What kind of wrench works well on the bleeder screws? I tried an open-end, box-end, and line wrench and all had trouble getting enough clearance to turn. Very tight space, esp. in the rear where the wheels are on. In the front I have the wheels off still so it was a little easier.
2. At the airpack and at the rear wheels, it seems there's no point at having a hose on the bleeder valve. When I loosen the bleeder screw, fluid comes out around the base not out the tip. I never got one drop of fluid into the hose.
End result: got the air out of the front where I had changed the brake hoses and one hard line, but still no pedal firmness at all. Right now I have a 13,000 lb lawn ornament and I'm not eager to try it again!
Any advice appreciated.
