dilligaf13
- 34
- 28
- south, florida
I need to replace my alternator and am not having a lot of luck getting ahold of Wolverine technolgies. Does anyone else make a bolt on 24V alternator replacement? Thanks.
What are you talking about my bracket is almost exactly like the stock bracket....You are confusing my brackets with the other guys stuff. Mine is nothing like wolverines brackets.. My brackets bolts on with the same three bolts that hold the stock bracket on and the adjusting arm goes on in the same location as stock? It is so simple a 8 year old could do it in less than ten minutes.Not to mention my brackets can be used with the 12 volt kit i sell or without it..I didn't like the upside-down mounting design of either tm america's or Wolverine's kits. Seemed overly complex and not robust.
