M35 Replacement alternator
1,823
The stock one is submersible. Won't charge underwater but will start working when it comes out. Don't know about the Delcos
goldwing2000
Banned
506
15
Ingham County, Michigan
What are you talking about my bracket is almost exactly like the stock bracket....You are confusing my brackets with the other guys stuff. Mine is nothing like wolverines brackets.. My brackets bolts on with the same three bolts that hold the stock bracket on and the adjusting arm goes on in the same location as stock? It is so simple a 8 year old could do it in less than ten minutes.Not to mention my brackets can be used with the 12 volt kit i sell or without it..
Maybe I'm mistaken. Does your system not mount the alternator with the single mounting tab down, the double tabs up and use an extension bracket that goes up to form a 90° angle to support the rear mounting tab?
DUG
Senior Chief/Moderator
74
Mesquite, NV
Good point. I doubt the Delcos would like being dunked. I guess it's a good thing I have the cheap spare in the back. I'm pretty sure mine won't be getting dunked (on purpose).
1,138
Yes, I strongly suspect the mil-spec unit is a higher quality unit than the new ones.
That's not to say the new ones aren't fine for our uses....................
LowTech
163
Arizona
Does anyone have the pulley part # for the si21 alt
This is what I just bought, "24-1509 PULLEY". And he wanted to know 1) what belt type 2) how many grooves, 3) the diameter 3.5
Don't have it here yet so I can tell you any more about it.
1,823
I think that before I deplete my inventory of stock alts, I will invest in one of these.
tm america
24
merrillville in
My kit the alt mounts exactly like the stock one.The two mounting tabs are at the bottom Which is where it pivots the adjusting arm goes to the mounting tab on the top . It mounts to the stock holes on the block and water pump. My brackets are cut out on my plasma table and welded in a jig a built to make sure everything fits right the first time please go look at the pics posted in my classified add before making incorrect statements .The wolverine kit is the one you are thinking about it requires the alt to be reidexed.. MY brackets are nothing like his... I put the effort into the design to make it easier to change the primary filter and to make sure it mounts the same as the stock one and uses the same belt..My kit is also about half the price as the other ones out the
tm america
24
merrillville in
Some of the pros of the delco alt is you can get them new for $115. They are readily avialible at most truck parts store.They are less rotating weight- rob less power from the engine.As far as weather they hold up to undwater use.. i have never had an issue But i have gone thru three stock alts on my truck with no warrenty.. The delco has a warrenty.I think the delco unit is a little less likely to burn up due to having a bad battery like the stock 40+yr old gens...
Cost is a huge pro for the delco alt you can buy a new alt for the cost of a used stock unit and at least you know what you are getting..
tm america
24
merrillville in
The part number for the pulley depends on the bracket... there are different belt widths, different diameters,and different off sets.. the offset is the biggest issue.. I built my brackets to use the stock pulley as most guys will have the one off the old alt..I have found a few that are very close to the offset of the stock pulley.. The closest i found was off by 5 mm.It seemed a little pricey at 30+ bucks..
yolner
68
Rockville, MD
goldwing2000
Banned
506
15
I stand corrected and offer an aplogy. I looked at your ad but the pictures are pretty fuzzy and out of focus so I guess I couldn't really tell how everything mounted up and having the dual alt setup in there kind of confused the issue even further. I may have mistaken yours for another that may have been listed elsewhere (besides wolverine). If I end up converting another truck, I will probably have to get your setup. The one I made was completely free but I no longer work where I had the equipment to make it, so yours is definitely the best option I've seen so far.
Again, my apologies.
With regard to pulleys, I opened mine up to 7/8" and also had to cut 1/4" off the back side of the spacer to align with the water pump. It puts the nut a little close to the fan but I haven't had any problems with it yet.
Loco_Hosa
Ethel, Wa
As far as alts going underwater, I will share my experiences from off-roading my XJ Cherokees, and my old K5. I have never killed an alt going through high waters. I have wondered if it took them a few mins to start charging again, but they always did. Thats of course not to say that they always will.
I believe my 91 XJ had the alt mounted low also (Its been a little while) and even the couple of times I hydrolocked the engine the alt was fine. Just pulled the plugs to let some water out and away it went!
Of course your mileage may differ, just didnt want people to assume just because it aint military it will crap out first time it gets soggy!
DUG
74
Mesquite, NV
Loco - that's good to hear, thanks for sharing. I've mudded with Delcos but never flooded one. Just looking at the stock alt compared to the delco I replaced it with you can tell the stock alt is beefier and better built. That being said, I would have to fry a lot of these 120 dollar delcos to add up to one brand new factory alt. To me it's worth it. The weight savings, etc might be nice, but for me it boiled down to spare part replacement cost.
The second alt to run a few 12 volt goodies was mainly just to look cool. :)
parlay100
Houston, TX
Just joined today. I own an alternator shop in Houston, I am a prestolite- leece neville dealer. Also have tons of the 22SI 70A if anyone needs one i will cut you a deal.
LowTech
163
Arizona
****, my timing has been off lately. Just bought one last week, and it just arrived.
So . . . question, If I just bought an "advertised" Delco, why is it not marked as such? Came in a box marked World Power Systems / WPS.
Everything I've been able to find links them, is that who really makes Delcos? Or is this just a cheap copy?
goldwing2000
Banned
506
15
If it's not marked either "AC Delco" or "Delphi", then it's not a factory part and is only a "Delco style" alternator. Not saying that there is going to be anything wrong with it, just hope you didn't pay a Delco price for it.
Edit: Apparently WAI Global is the company who manufactures the WPS products. Strictly an aftermarket manufacturer.
WAIglobal’s state-of-the art production facility and streamlined parts manufacturing practices help it consistently meet the quality standards and supply demands of the global aftermarket. Located in Shanghai, China, WAIglobal’s 100,000-square-foot manufacturing plant possesses the most advanced equipment and precision technology available.
http://www.wai-wetherill.com/overview.html
