Standard plow for a deuce?
dittle
72
Albia, IA
Short answer no, were some plows modified to fit on deuces Yes, but not specificaly made by the govt.
5,112
I've seen a few with plows on them, but all civy plows that were added on. I'm not much help since we don't get snow much were I live. Maybe someone from the more northern regions can speak on it more if the military ever used one. But I'm guessing anything you find will be an add on from the civy market.
hndrsonj
Senior Chief/Moderator
375
Cheyenne, WY
Not origionally. I would think that unless it has some kind of steering assist, it would not be fun to use plowing for several hours.
5,112
Oooh good point. The lack of steering assist would probably make plowing pretty dangerous.
1 Patriot-of-many
87
Zimmerman MN
Thanks a bunch gentlemen. Was thinking if there was a plow standard for the A3 I would try to pick one up. Guess I'll stick with my POS Dodge Ram 2500.
dittle
72
Albia, IA
Unless you're plowing big straight stretches of road the deuce would not be a good choice due to turn radius.
1 Patriot-of-many
87
Zimmerman MN
I was thinking my driveways, about 300' and 400' long, a few spots behind the pole barn ect.. Now that you mention it, plow for the deuce wouldn't be much larger than an 8' that I already have. Probably wouldn't be worth the time and effort.
Thanks again for the input guys.
Think I'm looking at GL too much and getting ideas..... :)
AceHigh
31
Lake City FL
Your A3 makes the job easier. You already have power steering and I personally think the auto tranny is a plus, esp with the transmission temp gauge and the 2 speed transfer case.
OK, now to find a plow. I have been watching govdeals for one and it has been few and far between. The state agencies use theirs till they die. I am still looking.
Good luck and keep up the search.
Katahdin
24
Scarborough, ME
Here's a good deal on a plow at Eastern Surplus, it might be an old orphaned page tho.
Looks pretty simple to control, Up then Down, guess that's really all you need with that thing....its a little bigger then an 8 foot plow. :razz:
Keith_J
1,328
Schertz TX
Also it was mentioned in other thread, the deuce is not exactly warm in the winter.
Fighting the wheel will warm you up quick. Plus the cab heater works better when you have a good load on the engine.
Another issue is the stock front wheels are at their limit with a winch installed. Mounting a plow will probably over-load the tires.
