HikerMan
- 0
- 0
- Boise, Idaho
Hey everyone, I bought my first CUCV a few weeks ago and have some questions about upcoming work I want to do to it...
1) Paint - want to repaint flat OD green instead of worn out camo scheme, I was hoping to do this as cheap as possible and can't really afford the high shipping fees of that Gillipsie paint and don't have the right tools. Can I rattlecan this M1009 and make it look halfway decent? I got one of those plastic handles for spray cans for better control...What paint should I use that I don't have to pay exorbitant rates for shipping off the internet? I got a can from Walmart od green for metal I was going to test...
Basically, can I rattlecan it with OD paint and it not look like total $#!&?
If yes, what prep work should I do for outside and inside? Should I wipe down with acetone before painting? If not, what are my other options?
2) Preventative maintenance - Planning on taking the CUCV on a 3 hour drive up to where I live now, what relatively cheap maintenance items can I do ahead of time with limited skill? Got AAA in case I break down
Already planning:
Oil and oil filter change
(Is this the correct oil filter? right part number but it just doesn't look right: https://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=FIL1092_0331190695
Flush and refill antifreeze coolant (live in mtns want to make sure it has antifreeze)
Check air filter replace if necessary
Treat small pockets of surface rust
Paint truck
Buy spare tire when possible
Change fuel filter? Is there a write-up how to anywhere?
3) Rust hole in passenger front foot area - got about a 3 inch rust hole there, what can I do to patch this without welding?
Sorry about the novice questions, I just really enjoy this truck and want to keep it running right and learn some skills
Already planning:
Paint truck
