jrobinson5093
- 0
- 16
- jakin georgia
Does any one else get a lot more power and smoke when the fuel filters are clogging up on the multifuel?
Smoke coming out of hole in block usually indicates that you really screwed up.Black smoke - usually indicates lack of airflow.
White smoke - usually indicates lack of fuel flow.
Smoke coming out of hole in block usually indicates that you really screwed up.![]()
I just noticed that you stated that you run 100% WMO that is mostly filtered. If you are not filtering all of your WMO very thoroughly, you will be looking for a new IP very shortly. IPs are expensive.i run usually 100% wmo mostly filtered. .
