So I had a little time last night to mess around with it and I can't see how it would be the bushing (unfortunately). Maybe I'm thinking about it wrong though......I would assume that if the bushing is worn and allowing the gearshift to sit too low to properly engage the fork, I should have vertical "slop" in the gear shift. I should be able to pull up on the lowest part of the shaft and feel play, and if I try to shift into first while I am pulling up it should engage. Is that a correct thought? If so, my gearshift has no play and I'm not able to shift into first even if I'm pulling up on the gearshift. (SIGH)
This gentleman you speak of in Dixon....would he mind if I called him and just picked his brain on my situation? I would love to have him fix mine, but the 817 mile trip there without 1st or 3rd might be a little tough. I'm honestly nervous about digging into this deal because for one, its a Unimog and stuff ain't cheap and two, I am completely intimidated by transmissions. Also, what should I expect when it comes to tipping the cab? I assume I'll need to remove the front loader mounts, but will I need any other special tools and what is the best method of doing the "tipping" without damaging anything (including myself)?
If anyone knows of someone in my vicinity (eastern WA/north ID) that has experience with a 419 I'd love to talk with them. Shoot, I may even pay them to come over and show me what to do if that's an option. Thanks for the info so far. I'm really wanting to get the old girl fixed....it makes me sad seeing her sitting there every day without moving.
