Bluewater1104
- 0
- 1
- New Mexico
Noob question what is the oil capacity for the flu419 transmission oil?
Steel Soldiers now has an offical calendar available, read more about it at: Steel Soldiers 2021 calendar
If it doesn't leak so badly that it comes out faster than you can fill it, just add to the level plug and call it done.
Okay, so I don't remember. But where in NM are you?
I'm in bluewater New MexicoIf it doesn't leak so badly that it comes out faster than you can fill it, just add to the level plug and call it done.
No a link to the thread would be awesome I'll post pics tomorrowOkay, too far to drive a FLU over here, but not all that far with a road worthy vehicle, either.
Post some pics, would you, and maybe give me/us an idea of what you expect to do with your SEE.
Have you started reading the lengthy but very informative "Owners" thread yet?
What is this for I cant get it to the unlock position?Hint: It's by far the largest thread here. If you can't find that one, you probably shouldn't have a SEE.
Ejection seat. I’m surprised they didn’t remove it. You are lucky.What is this for I cant get it to the unlock position?
Lol I think I figured it out lol tyEjection seat. I’m surprised they didn’t remove it. You are lucky.
take a look at the lube manual it has capacities for most of what you are interested in.Noob question what is the oil capacity for the flu419 transmission oil?
One of the things you should also check before tipping the cab and diving into that project is the shifter bushing. It is the bushing that the shifter rides in and they do deteriorate with time causing the shifter to sit to low in the collar and then the shifter doesn't engage the shifter forks properly. You can get to it by pulling up on the rubber boot housing from inside the cab and then from the side sticking your hands in through the passenger side it will have a metal collar the detents down and putting downward pressure and turning it I think counterclockwise and it will let you release the shifter (BTW you need to disconnect the 3 airlines for downshift lever if you want to pull it completely out). You should have two guide pins on the inside of the transmission collar and they have to be removed to get the bushing out. Hope it helps
You posted in it. Go back one page.I have the same issue with my MOG, starts up by not going forward, do you know where the thread is located on this forum that tells you with pics how to replace the bushings without tilting the cab? I found it a few months back and not able to find it now. Thank you. I remember it to be a very long post.
Hello Coolhandmatt, I have just joined the 419 club, and after about 25 miles, my shifter became wobbly and will not go in to 2nd and goes poorly into the other gears. I can still drive it but it is obviously not right. I am basically in the same predicament as Watchman7 above.I have the same issue with my MOG, starts up by not going forward, do you know where the thread is located on this forum that tells you with pics how to replace the bushings without tilting the cab? I found it a few months back and not able to find it now. Thank you. I remember it to be a very long post.
