ChaoticCaveman
- 0
- 1
- Minnesota
I just purchased a SEE. Hi, Lo, R, 3rd & 4th seem good. No 1st gear and barley into 2nd (will move but probably jump out of 2nd if not holding shifter). Y'all think it's the bushing?
probablyI just purchased a SEE. Hi, Lo, R, 3rd & 4th seem good. No 1st gear and barley into 2nd (will move but probably jump out of 2nd if not holding shifter). Y'all think it's the bushing?
Seeing as you drive yours a lot from what I understand Gary, I’d highly advise you do it. I was 5 miles from my place when I was stuck in second gear. Doesn’t seem like a real hard job after removal. I’d hate to be stranded. Cause of a piece of plastic lolI haven't replaced mine, but I did purchase new ones from EI and they were both off-white, not black.
Silly question. Upon visual inspection, my bushing seems to have only slight wear and discoloration. It should be obvious it's bad, correct?
How badly was it damaged when ir stranded you? Did it break apart into pieces?Yeah that doesn’t look terrible, but there’s some wear on the left and right sides. If it were me, I’d spend the 20$ to replace while you’re there. Mine was shifting 100% fine one minute and almost left me stranded on a dirt road 10 miles from civilization the next lol. Was able to get it into second gear and drove home
when I got it home and pulled the shift lever there wasn’t much left. Just got the new one in the mail and it appears it was 80% gone lol. Had no idea it was so big beforeHow badly was it damaged when ir stranded you? Did it break apart into pieces?
lol wish! I did find a steering component end link boot that is destroyed while I was under it yesterday. Think it’s just gonna stay that way for now as I don’t drive it much. My mog is simply a ranch tool.Great to hear you were successful! You are becoming an expert on everything FLU.
