Last night I made good progress. I was able to get the gate reassembled and operational. As with most gates o work on without doing welding and adding a strip to the top outer flange this gate is structurally unsound. It works and opens and closes fine but the outer skin is corroded from the structure inside the gate. It works and I am not restoring this vehicle. Everything fits nice. I bought the used GM manual regulator from a YOUPULLIT after one of the vehicles I repaired for a customer ended up in the scrap yard after an accident. That was not even 6 months old.
![IMG_2296.jpeg IMG_2296.jpeg](https://www.steelsoldiers.com/data/attachments/683/683762-45f17288a068ce3d383a4adb5abcf82d.jpg)
I wasn’t sure if the angle of the crank looked right but that is when I can tell the gates structural strength is compromised.
![IMG_2288.jpeg IMG_2288.jpeg](https://www.steelsoldiers.com/data/attachments/683/683765-d1f2325c0ab4aee8985485f0f15350a7.jpg)
It looks good and for the first time in 6 months it is closed up from the elements.
![IMG_2292.jpeg IMG_2292.jpeg](https://www.steelsoldiers.com/data/attachments/683/683766-eb13e0844960c3ee7235a2cd72fef3d3.jpg)
Even the fillers fit perfect and tight in place.
![IMG_2287.jpeg IMG_2287.jpeg](https://www.steelsoldiers.com/data/attachments/683/683768-5b7e55ce5f74893a151839bde86a0dc6.jpg)
After I had everything adjusted and working I applied grease and oil. Real oil and real grease. No aerosol crap.
![IMG_2285.jpeg IMG_2285.jpeg](https://www.steelsoldiers.com/data/attachments/683/683770-04c0583334ada476308439566860489c.jpg)
This is the used regulator. Dusty but not rusty. Making great progress so I bolted on the Pinter hook assembly. That was held on with 2 bolts when I removed it. I used the 7/16” bolts and am ready to crawl underneath the next time I get to work on it. I need to button up the driveline on my next project. I still have the front lighting harness and get the electrician system charging again. That will happen. Everything I get to has been hacked on done incorrectly. Common on older vehicles especially CUCV’s. Take Care and Be Safe.
