Mep 803a No/Low Low Power Output
Iron.Horse
Frederick, Maryland
10 terminal block reads 12.2 on upper wires, not disconnected. Little tricky to get in there. A1 test, with wires disconnected is a crazy bizarre reading in the 60.0 range. I triple checked it and every time got a different reading, but it was definitely no lower than 50-60 ohms
kloppk
4,060
Pepperell, Massachusetts
The resistance should be the same 12.2 at 10 Terminal block AND across the two wires behind the gauge panel.
Your 50-60 ohms indicates a poor connection between 10 and one or both of those wires.
I mentioned to check, inspect, clean the P4/J4 connector pins in post #12. Did you do that?
Iron.Horse
Frederick, Maryland
Yes sir, found J5, pulled it apart and sprayed it with electronics cleaner. I honestly have looked everywhere for P5 but haven't found it yet. I'll try to look again for it.
kloppk
4,060
Your DMM is actually displaying 76,300 ohms (7.6 KOhms)
P5 and J5 connect together.
J5 is bolted to the floor of the compartment behind the gauges. A small black connector with 4 wires..
P5 plugs into J5 behind the right access door.
P5 also has 4 wires.
Do you know how to decipher the -24 TM to figure exactly how it's wired from A1 to find 10?
The TM wiring method can be confusing to figure out...
edit:
Here is a quick drawing showing the actual wiring...
Iron.Horse
Frederick, Maryland
edit:
I Really, Really appreciate the drawing and help... The tracing of wires makes a lot of sense, I pulled J5 again and sprayed it, traced the wires and looked for rubs and chews, they look fine. The original spade connectors were replaced with permanent crimps, wires seem solid. I guess I could cut them out and re-splice for good measure? Wires seem fine going into gen head, no rubs, but I can't see where the one set terminates on the... coil? Only the other set on number 10.
Should I cut out the larger wire that lays on the gen head and replace from the plug to where it enters the head? That would eliminate a few feet of wire that could have internal damage?
kloppk
4,060
Don't cut any wires yet. You need to do some more measurements to isolate where the problem really is.
Based on your reported measurements there is an issue with voltage making it from A1 to the two Find 10 terminals.
What needs to be done are some continuity measurements on the wiring between the two.
All continuity measurements below would be a resistance reading of about 0 ohms.
Disconnect P5
1) Check for continuity from one of the Find 10 terminals to P5 pin 1 or P5 Pin 2. One or the other is connected to P5-1.
2) Check for continuity from the other Find 10 terminals to P5 pin 1 or P5 Pin 2. One or the other is connected to P5-2.
If you find "continuity" for the two wires in steps 1 & 2 above, then proceed to step 3.
3) Check for continuity from J5-1 to Terminal Block 5 terminal 17.
4) Check for continuity from Terminal Block 5 terminal 17 to the wire that goes to A1 terminal 6.
5) Check for continuity from J5-2 to Terminal Block 5 terminal 18.
6) Check for continuity from Terminal Block 5 terminal 18 to the wire that goes to A1 terminal 5.
Post up your findings and we'll go from there.
LuckeyD
151
33
Vilseck, Germany
That TB 10 is located inside the main gen and you have to remove the main gen back panel with 6 bolts if I remember right. Only had 2 60HZ issues with this and both had an eaten wire from that TB to the exciter stator. The rest were 400HZ gens. Test is to start the gen set holding the S1 in start to see if an AC Voltage is produced on a panel gage or meter connected to K1, on the S8 side of the K1, L3 to chassis. If something shows then goes away as you allow the S1 to go to the run position, you have a better way to TS the thing. At the moment and if I followed the thread correctly, this could be a Mag pickup, S14, K15 K16, fuse, regulator or wiring as I have repaired several by ensuring all terminals were tight. Mr. Kloppk is testing the regulator at this time. It goes with the attachment. I hope it tests OK as it is costly. Forum members have this guy taken care of. You can test the main gen by connecting a 9VDC transistor battery to Wire 104C disconnected from A1 B+ terminal 6 ( the F+ ) and wire 105C usually connected to A1 terminal 5 B-(F-) Apply for a moment or two only while engine running. This will test if the main gen is OK as you should read about 70-89VAC or something and now you can be relieved it isn't something costly like a main gen. OH, If the freq meter is working the main gen is usually OK.
