MEP-803A - New to me, excited to get it going.
KD7CAO
58
13
Aubrey, TX
Thank you for the suggestions everyone. I am cancelling the order on the parts and gaskets. Company was deceptive in their advertisement, raised the price on me after I ordered (PayPal notified me thankfully). Now trying to get a refund from them so I can order from somewhere else. The push rods are coming from forum member so those will be okay. I think the one bent valve isn't actually bent, just has a mass of carbon stuck to it that prohibited it from pulling out properly. Looking into ultrasonic cleaners right now too. But CLR is a lot cheaper so going to give it a try too.
2Pbfeet
1,475
Mt. Hamilton, CA
@KD7CAO Just a heads up; gun barrels usually have a surface treatment that makes them more corrosion resistant, e.g. bluing, or nitriding. Plain steel, like a valve, will corrode in acids, e.g. CLR, so keep a close eye on the parts if you do use it. Remember the old experiments with Coca-cola (pH 2.4+/-) and a nail? Per the MSDS for CLR, it is about a pH of 2.2, so even more acidic.
I'm not saying CLR won't work, but I personally wouldn't use it on engine parts, for this and other reasons (hydrogen embrittlement).
All the best,
2PbFeet
Icesythe7
230
Indiana, USA
When I cleaned the carbon out of my 1.9l turbo diesel car project I found what worked best for me was oven cleaner, after 30 mins of that most of it just washed off perfectly clean with pressure washer, the remainder i heated up with map gas (not a torch) and once hot used a metal coat hanger i stretched out (like grab the hook and center of straight bottom and pull away from each other to make a skinny diamond shape) and cut the hook off to where it is twisted and put that in a drill and other end in the manifold and that got everything I couldnt reach by other means extremely well.
