MEP-803A - New to me, excited to get it going.
KD7CAO
58
13
Aubrey, TX
Thank you for the suggestions everyone. I am cancelling the order on the parts and gaskets. Company was deceptive in their advertisement, raised the price on me after I ordered (PayPal notified me thankfully). Now trying to get a refund from them so I can order from somewhere else. The push rods are coming from forum member so those will be okay. I think the one bent valve isn't actually bent, just has a mass of carbon stuck to it that prohibited it from pulling out properly. Looking into ultrasonic cleaners right now too. But CLR is a lot cheaper so going to give it a try too.
2Pbfeet
1,501
Mt. Hamilton, CA
@KD7CAO Just a heads up; gun barrels usually have a surface treatment that makes them more corrosion resistant, e.g. bluing, or nitriding. Plain steel, like a valve, will corrode in acids, e.g. CLR, so keep a close eye on the parts if you do use it. Remember the old experiments with Coca-cola (pH 2.4+/-) and a nail? Per the MSDS for CLR, it is about a pH of 2.2, so even more acidic.
I'm not saying CLR won't work, but I personally wouldn't use it on engine parts, for this and other reasons (hydrogen embrittlement).
All the best,
2PbFeet
Icesythe7
230
Indiana, USA
When I cleaned the carbon out of my 1.9l turbo diesel car project I found what worked best for me was oven cleaner, after 30 mins of that most of it just washed off perfectly clean with pressure washer, the remainder i heated up with map gas (not a torch) and once hot used a metal coat hanger i stretched out (like grab the hook and center of straight bottom and pull away from each other to make a skinny diamond shape) and cut the hook off to where it is twisted and put that in a drill and other end in the manifold and that got everything I couldnt reach by other means extremely well.
KD7CAO
58
13
Aubrey, TX
Today started off nice. I purchased an ultrasonic cleaner and put the valves, exhaust manifold, and some other items in it. Took a month of running it every few days and lots of soaking in detergent but I got most of the creosote out of the manifold.
I was just looking at the little hydraulic pushers of the push rods. Sad to report that two are toast. Stuck a magnet down inside and it just started to pull guts. Two flat metal plates, no retention clips, the little seat for the oushrof, no springs. Not good. After fighting for several weeks to get new gaskets, not sure how this is going to work. I talked to Lister Peter they have ceased making parts, they recommend searchint Chinese suppliers. Most of them are advertising, but don't have any on-hand parts. 6-9 month lead times.
KD7CAO
58
13
Aubrey, TX
Are you in need of some lifters, is that what you are saying? How many do you need, I should have a couple used sets.
Sorry, my last post was on a day that everything seemed to be going bad. I may very well be interested in some used parts, I found new ones available for $20 each.
What is the general consensus, do you replace all of them if you have issues like I am finding?
