MEP-803A - New to me, excited to get it going.
Ray70
7,166
West greenwich/RI
In addition to that data plate above, sometimes you may find a data plate from an engine rebuilder with the piston overbore, rod and main undersize engraved or stamped into the plate.
But most of the time if it's a Lister Petter data tag as shown above, those are usually standard sizes, unless noted otherwise.
KD7CAO
58
13
Aubrey, TX
I took a look and did not find a data plate on the engine itself as shown in the photos. There is one that I didn't see that showed up under the oil filter in a picture, I need to look at it more closely to see what it says. I am really tall, and I guess at the angle I was at, I couldn't see it till the corner appeared in a photo.
2Pbfeet
1,491
Mt. Hamilton, CA
Is your unit a Tier 1 or a Tier 2 reset?
The one under the oil filter is usually the National Security emissions exemption statement. Not having a remanufactured label suggests to me that whatever caused the unit to be sent for reset wasn't something significant to the engine, per the document that @kloppk posted above.
All the best,
2Pbfeet
P.S. @KD7CAO FWIW: I use my phone to get photos of items in awkward locations. Blind point and shoot in my hands usually takes a few iterations.
KD7CAO
58
13
Aubrey, TX
The one under the oil filter is usually the National Security exemption statement. Not having a remanufactured label suggests to me that whatever caused the unit to be sent for reset wasn't something significant to the engine, per the document that @kloppk posted above.
All the best,
2Pbfeet
Oh I do as well all the time. My Samsung has the pen and I can use the button on it as a remote shutter control.
It is Tier 2 and has reman/new engine 2.5 hours.
KD7CAO
58
13
Aubrey, TX
Just wanted to give you all an update, weather has been crazy here in North Texas and so I have not been able to work on it in the evenings after work. I am currently looking for a used trailer to put the generator on which will make it much more accessible to me than in the bed of the pickup.
I've got the manifolds off and started looking at the technical details for pulling the head. Looks like I need to get the water pump and alternator off next. I am starting to wonder who else has been in this engine, some of the bolts so far have not been torqued, very easy to remove.
Good for me but makes me question how far into this engine I will need to go.
spotrep
142
33
Texas
Just wanted to give you all an update, weather has been crazy here in North Texas and so I have not been able to work on it in the evenings after work. I am currently looking for a used trailer to put the generator on which will make it much more accessible to me than in the bed of the pickup. I've got the manifolds off and started looking at the technical details for pulling the head. Looks like I need to get the water pump and alternator off next. I am starting to wonder who else has been in this engine, some of the bolts so far have not been torqued, very easy to remove. Good for me but makes me question how far into this engine I will need to go.
My father will sell you his trailer! Its an MEP trailer, an M116A3 i think theyre named. We have the equipment to get it off your truck and onto the trailer too! He bought his unit on the trailer but now it lives on a concrete pad.
KD7CAO
58
13
Aubrey, TX
Thanks but I picked up an old welding trailer on Friday, new tires and coupler today, and got the generator temporarily mounted on it. Thankfully my boss knew a guy that had a skid steer and just happened to be working next door to my house. Just had to drive it over due to a fence in the way.
Sent from my SM-S928U using Tapatalk
KD7CAO
58
13
Aubrey, TX
Went ahead and took the rest of the pushrods out tonight. I would say at least 5 are damaged. Have not done the glass roll yet to check the rest, four intake are majorly bent, one exhaust is very rusty.
Number 1 cylinder has heavy carbon deposits.
Exhaust manifold was caked inside.
I will get pictures tomorrow when there is day light.
KD7CAO
58
13
Aubrey, TX
Checking cylinders with my finger, they feel smooth. There is a little surface grit in number one that looks rusty, but it is on the surface only. The carbon on the pistons is thick, it does not come off with a simple shop towel.
What tool do you recommend for removing the spring keepers on those valves? The tool in the TM is $1800 new and I have not located a used one, surely there is a more economical version available though.
2Pbfeet
1,491
Mt. Hamilton, CA
@KD7CAO that's an impressive amount of carbon in the manifold and an impressive amount of oily/greasy unburned diesel and carbon on the piston heads. I'd start with carb cleaner. If you use compressed air, try to have it going across the top of the piston head, rather than down to minimize dust getting between the piston and the cylinder wall.
While my favorite way to clean pistons is out of the block, if it is in the block, I like to have them TDC when cleaning, both for access, and to be better able to clean the piston ring area better when I'm done and give me a chance to wipe the cylinder wall clean as the piston goes down after cleaning everything. I like to fill the other cylinders with rags and cover the rest of the head with a towels to minimize debris going elsewhere when cleaning. YMMV.
All the best,
2Pbfeet
KD7CAO
58
13
Aubrey, TX
Just wanted to let you all know that life got in the way, the wallet got lighter, and this got pushed off to the back burner a bit. I plan to pick it back up soon (although it is a bit on the warm side to work on it). However, spending 2 weeks running communications for the Guadalupe River Flooding event, it kind of speared me to move forward getting my generator operational.
KD7CAO
58
13
Aubrey, TX
A few parts ordered new to me Push Rods from a forum member, new gasket set and ordered new valves. One appeared to be tweaked a bit from the excessive amount of creosote like substance in the exhaust.
So, I have tried a few different methods to remove this creosote like deposit. Soaking for weeks in a soapy substance, spraying with carb cleaner, then brake cleaner. Now, lots of elbow grease with a screwdriver. Tried a brush in my drill and it didn't even budge this stuff loose.
The head, exhaust manifold, and I can only assume muffler are all going to be like this.
Any thought on how to clean?
2Pbfeet
1,491
Mt. Hamilton, CA
Yes, heat for the exhaust manifold, but try not to locally get any area too hot as you can warp or crack the casting. To the extent that you can access the spaces, a needle gun will be helpful in the manifold, but I wouldn't try it on anything else. Ditto a carbide die grinder. Glass bead blasting is possible for the manifold, and for the disassembled head, but I wouldn't make sure to tape up the precision areas. For the piston tops, I don't know of anything beyond wire wheels and abrasive wheels, but, personally speaking, I hate to use abrasives on piston surfaces when the pistons are in the block. If it were me, I would get the heavy carbon off the piston surfaces, and call it good, knowing that working the generator hard in the future (100% loads) will burn them off, especially if you add some anti-carbon additives to the fuel. For small items, like valves, ultrasonic cleaning in a high pH bath may help, but I would first try to mechanically remove as much of the deposits as possible. FWIW: Some wire wheels are more aggressive than others, e.g. coarser, stiffer wire, and one can always sharpen the wire wheel on an abrasive stone. Personally, I try to sharpen the wire wheel in reverse compared to the direction thatI'm using it in, but either way works.
The solutions that I have worked with that can lift carbon are pretty darn corrosive, and I've never tried them on anything beyond borosilicate glass, stainless, and teflon. They are pretty hard on even straight glass. But I wouldn't claim to know all the de-carbonizing solutions.
All the best,
2Pbfeet
