Mep-802a aux fuel pump trips breaker?
ribs1
Michigan
What is the best way to test a 24v pump out of the generator? Get 2 batteries? Get a 24v battery?
Also, just browsing in case I need to buy a new pump it likes like they start at about $80. Weren't they really cheap at one time?
2Pbfeet
1,497
Mt. Hamilton, CA
Two 12V batteries do work. If you do this much at all, a bench power supply is a lot cheaper. You set the voltage (and/or current), and can test away.
Pump prices vary a great deal. With the current uncertainties around import costs, I would anticipate even more variations in prices, so probably a time for even more comparison shopping.
All the best,
2PbFeet
ribs1
Michigan
All the best,
2PbFeet
Thanks for that. I'll shop for a bench power supply. I'm sure I would have other uses for it as I maintain 2 small tractors and a bunch of other equipment.
It looks like the Facet brand pump runs $80-120 but I can get an off brand for $40. any reason not to get the off brand?
2Pbfeet
1,497
Mt. Hamilton, CA
There are off brands, and there are off brands. To me, the risk with "cheap" ones is reliability.
FWIW: Rock Auto is having a close out at the moment on the 24V Carter P74018 pump, and you could get two for less than $40, plus shipping. 1/4-18 NPSF threads inlet and outlet.
I believe that Carter bought Airtex, and the P74018 is the Carter replacement pump for the Airtex E1074. I would double check that the threads on the P74018 above match what you have or need.
All the best,
2PbFeet
