- 1,314
- 2,531
- 113
- Wenatchee, WA
Dang, that's a mess!
Just plain simple is hard to beat, you know?M931A2
I eliminated the fuel tank control valve in the cab, now fuel pump is hooked directly to the drivers tank only .
It already runs better .
Nothing weird ay all about that fabrication, US6x4; that there is an excellent piece of work!I made a weird bracket that straddles the back of a cargo hold down to mount my VRC antenna base and antenna element. I mounted it to the passenger side so it wouldn't interfere with unloading a full size spare tire and because the radio is also on the passenger side.
Next up is to wire up the aerial and install the radio under the seat!
Could you make some more brackets?I made a weird bracket that straddles the back of a cargo hold down to mount my VRC antenna base and antenna element. I mounted it to the passenger side so it wouldn't interfere with unloading a full size spare tire and because the radio is also on the passenger side.
