the throttle cable on this set ended up being no good. it actually worked ok but the nuts on it were completely frozen and with a little effort they just stripped out. it seems the 003 and 002 use the same cable even though the 002 is shorter. this makes the factory 002 cable kinda long so i figured if i was going to replace it i might as well go aftermarket and get or make one that fits. the style cables that are on these gens are called "vernier" cables. you can find them all over the net. i got mine shipped from the big auction site for $45. its 10ft length and a solid core unlike the original which is braided cable. its a relatively straight shot with no bends so should work nice and smooth. after searching the real kicker is the cable end. when you buy these things they are just plain cable core and no nuts or threads to hold the end in place. i did some searching and found an aircraft supply house
www.aircraftspruce.com. they have all kinds of vernier cables and accessories for them. all their stuff is aircraft/faa approved and of real nice quality. i found this awesome little piece that fits the cable housing end. took a pic with the part # if anyone needs one. the cable i bought has a 3/8 outer casing size so this fits. the also have a smaller 1/4" model to fit the cables they carry. this pieces is split in half and the very end is split in quarters. when you tighten the end it squeezes down on the casing clamping it in place. the other big nut will work and fit in the same location as the factory cable.
now i needed a fitting for the end of the cable. they do carry an end that converts the cable to 10/32 thread then you can thread a fork on it just like the factory cable. to keep cost down on this a bit and to make it simple i went another route and order this from the same place.
this isnt one of the little cheap ends you see on your lawnmower. this thing is really nice. its all hardened steel and machined. only thing i will need to do is take a drill and make the hole slightly bigger on the governor arm on the generator so this b-nut goes in. the blue housing end ran $18.95 and the "b nut" was $7.95. shipping for the order was $7 plus the $45 for the cable shipped to my door. total i got $79 in the whole thing and i got some good well made pieces. here are some pics of the cable i got.
![IMG_1451.jpg IMG_1451.jpg](https://www.steelsoldiers.com/data/attachments/297/297512-72a90c344a92f88a5c3ada114beb941c.jpg)
seems like a fairly decent cable. no complaints on it. the ones aircraft spruce carries are probably quite a bit nicer but are $25-35 more. i thought it was prob unnecessary since most of us set the speed on our gens and never touch them after that.
