ranchhopper
- 136
- 63
- south elgin illinois
I have a 1009 with an engine losing coolant and seems to be getting into the crankcase. The engine has a lot of blowby which could be caused by the coolant leaking into the crankcase I drained the excess oil out while it was warm and it had a lot of steam coming off it as well. The oil has a weird smell to it and no milkshake look to it which is strange most coolant in oil produces a real mess not the case here. I have a 305 block and heads that were completely redone at a machine shop years ago and its been sitting in the garage for years. The 6.2 needs an injector pump it weeps diesel out the front I think for the money I can finish putting together the 305 and put it into the truck for way less time and cash than fixing up the old 6.2. I will have a brand new engine instead of a patched together 6.2 what would guys here do I'm interested in hearing you opinions. I think the torque converter and governer would need to be swapped out in the transmission and I may be able to use the power steering pump from the 6.2 to run the hydroboost. I may not even need the hydroboost with the gas engine unless the 1009 has JB8 brakes but I doubt their that heavy duty on a blazer.
