16.00 R20's (52"tall) on a deuce! pic's too
hot rod deuce
Kasota, Mn
well her she is my 19?? deuce n a half with 16.00 20's just thought some one might be interested in a peak. the pics are in the middle of a 5.9 cummins swap so the front is a little outa shape but it kinda gets the point across id be happy to answer any questions if you are interested or would like a similar set up. it does help out the gearing ALOT, makes 55 2100
www.imageevent.com/tabs/armytruck
Desert Rat
HRD;
Is that engine from a Dodge or what? Plus, what about the tranny, original or swapped too? Those tires are beheamoths! Looks like quite a bit of $$$$$! Could you run down in a general kind of way a start to finish list and name important parts modified and/or swapped to let her run properly? I'm looking to get some bone trucks in the future to help the farmers in this general area and this looks like a good modification they can use and customize to their needs. Thanks! Plus a ballpark figure on a budget would be nice too.
Hot rod duce
Sure no problem
ill start with the tires and lift/spread.
I made a 3 inch lift for the front and rear by making the frame 3 inches taller (added on the the bottom) then i had to spread the rear axles, that involved pressing the rubber joints from the stock boggie arms and into my new ones. i made from DOM tubing. the rims are the trickey part. i used 12 rims total. 6 welded center and 6 riveted. cut 3 inches from the riveted ones and add it to the welded center wheels...pooff 10.75 inch wide rims.
Cost: $1500 tires and tubes
$500+/- materials (just stuff i had layin around so it was no cost to me)
the motor is from a airport shuttle bus i paid $2000 for that with EVERYTHING the front half of the frame, after cooler, radiator, driveshaft, muffler, i even got the cruse controle unit and power steering. then i had to buy a flywheel and clutch for $600...ouch that one hurt. used the stock tranny to save cost and the rest of the stuff is all there.
now i dont think i could do it for that price again. i didnt go looking for the parts i just hung out till i stubled apon them cheap and said "hey i could use that for somthin"
now i just gota find another cab cheap so i can make a crew cab....
1,827
Holy sheepcrap! That thing's wild looking. Press on at will, I wanna see this one complete! Question, since you made your own longer arms to spread the rear axles, did you have to use a longer main leaf?
Longhunter7
9
Northern Illinois
Hot Rod Deuce!
Great looking Deuce! <img src="emoticons/icon_smile_cool.gif" alt="Cool">
If you are interested, maybe you could do a feature article for all the members to check out!
Keep us posted and take lots of pictures! <img src="emoticons/icon_smile_thumzup.gif" alt="Thumb Up">
Monster Man
yes yes yes! AR-TI-CLE AR-TI-CLE AR-TI-CLE
sweet, man, I'm drooling over here. Great job, if it's no trouble could you snap some bigger pics and e-mail me ? I'd love to see some details of the longer tubes you made, the front lift and what mods exactly were necessary to fit the tires, and of the custom wheels. All of it really. <img src="emoticons/icon_smile_approve.gif" alt="Approve"><img src="emoticons/icon_smile_approve.gif" alt="Approve">
Desert Rat
HRD;
I second MM's motion with plenty of inertia! The potential to the farmers around here is great! I'm trying to figure out feasibility issues....... Any and all help generously appreciated here!
Trango
23
Boulder, CO
Holy amazing metal fab.
I'd love to know what you used for your bottom leafs as well as the arms! I have made quite a few suspension arms, but nothing for a 14k vehicle. I'd probably make then out of quarter wall HREW (not DOM since I'm cheap)... what OD and wall did you make em out of?
Bob
Loose Deuce
South MS.
WOW, Monster Deuce! I bet it would be fun changing a tire on the road. Looks Cool<img src="emoticons/icon_smile_cool.gif" alt="Cool">
hot rod deuce
Kasota, Mn
sorry for the late reply, ive been workin 12's so i havent had much time to read the forum or even work on the truck, the rear leafs were custom made to my specs by a spring manufacture here in minesota. most of the metal work still needs sandblasting and paint. my plan is to tare the whole thing down for a blast and paint after i get the crew cab made.
Monster Man
I personally like it without the crew cab, looks perfect! is the family complaining about not being able to ride or something? <img src="emoticons/icon_smile.gif" alt="Smile">
hot rod deuce
Kasota, Mn
nah just thought it would be neat to have a crew cab deuce<img src="emoticons/icon_smile_shrug.gif" alt="Shrug"> seemed like a fairly simple mod. off road events usualy turn out to be more fun with more more people.
Monster Man
any new pics? <img src="emoticons/icon_smile_approve.gif" alt="Approve"><img src="emoticons/icon_smile_big.gif" alt="Big Smile"><img src="emoticons/icon_smile_approve.gif" alt="Approve"><img src="emoticons/icon_smile_big.gif" alt="Big Smile"> I want to see that thing running over a car!
