Kaiser67M715
- 26
- 18
- NH
Does your MC bolt look anything like the early deuce MC bolt? There's nothing like a gasser so I'm hoping you get this on the road so we can hear it. Give up a picture of your MC and lets find you a cap!All lines in, letting it gravity bleed, will fully bleed tomorrow.
Do Need to figure out something for the master cylinder cap, no source for the copper gasket I can find, will try to find an o-ring at some point
The flat plastic washer from the plumbing isle, intended to fit sink traps etc. is a perfect fit. Bring your cap; I think it is the 1 1/4 inch diameter.Here's a picture of the cap(I have two, one from the master originally in it, and the new one I installed)
I'm gonna see if I can get an o-ring, and/or find one of them plastic washers
When I get home this evening, I will look up in my TM how to test. There is a way but I don't remember the process without the manual. The test works.I've never run a truck with three condensors, plus I don't know how to check if they are good, which is giving me the biggest issue.
