1952 studebaker M35a2
Jvanderburg
Oklahoma
Thanks this is my first M35 I don't know a lot about them so I'm hoping to learn a few things on here. So far the only problem I found is the brake lights arnt working
Sent from my SAMSUNG-SM-G900A using Tapatalk
Scar59
41
Mt. Eden, KY
Welcome from KY, truck is in very good shape for it's age. Brake lights are controlled at the 3 lever light switch. Find the operators manual, it will answer a lot of questions.
m109a2
lake charles la.
Welcome to the site.Like Scar59 said the brake lights are fed from the three lever switch cluster,Turn on your lights then check brake lights.If no I would check the lamps with a meter and the grounds.If that does work for you go to the source hit the backside of the switch if 24 volt move down to the brake pedal switch Just remember this is a very old truck and age takes it`s toll on everything and everybody.Give me a call 337-477-1067,Al.
Jvanderburg
Oklahoma
I have been looking through the manual all of the lights are working correctly even the Bo lights it's just the brake lights. I am trying to find out where the brake light switch is located but haven't had much luck. The truck is in great shape I was told by the previous owner that it sat in Fort smith Arkansas in a museum for several years before he got it.
Scar59
41
Mt. Eden, KY
Time to get into the maint. manual(TM). -24. Real simple system, brake pressure switch is on the air pack. Also, get a meter and shoot some wires, may be a simple broken wire. Switch is probably very old and stuck. Report back.
JC
SignalNco
Winchester, VA
Welcome to the obsession. Wow, looks to be in really great shape for the age. I had a problem with mine when I first got it. There is a connector in the harness about half-way back under the truck. Mine was a plug and socket amphenol type connector. Took it apart and sprayed some contact cleaner on both parts and worked the connector in and out a few times. That took care of the problem in mine, been working ever since. Good luck.
