Boy now I feel like a dumb A$$
![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
......hope you weren't offended....we do get a lot of kids on here that just tap away on their little smart phone with no regards to spelling and what not......makes it hard to read......I hope you can accept my full apology!! And I want to thank you for your service....
I also wanted to let you know that the 2 final fuel filters can be had from NAPA the part numbers are:wix# 33540 and #33512 be sure to use both......one is a 10 micron and goes in the secondary, and the other is a 6 micron and goes in the final.....I don't know the # for the primary(I switched over to a spin on)
Also I meant to tell you last time to check your fuel pump fuse......most of the time that is all that is wrong with the pump....you can find the fuse under the square cap on top of the tank see Photo
![IMG_0022.jpg IMG_0022.jpg](https://www.steelsoldiers.com/data/attachments/304/304805-3014e3686431de7ef70adbf5b2a512bb.jpg)
![IMG_0023.jpg IMG_0023.jpg](https://www.steelsoldiers.com/data/attachments/304/304806-810171a1f14818e86826adb34562ab0b.jpg)
Remove the 3 nuts on the cover and turn over, you will see a tube fuse in there.
