- 6,154
- 4,866
- 113
My guess says no. The 939series trucks came originally with 11r20 NDTs.Someone with an 809 series changed out the wheels and tires with your 925.
Does your dash have the ABS light?
Those are 11.00's, NDCC, exactly like my 817 had.My guess says no. The 939series trucks came originally with 11r20 NDTs.
The same wheels and tires were also OEM on early 939a0 trucks. I saw some go recently at auction with the NDTs still in place and no ABS. I'm willing to bet this is one of those trucks.Those are 11.00's, exactly like my 817 had.
I'm saying I think someone traded them because they wanted the G177's that came off of his 83-84 923(A0) to put on their 809 series. I wanted to make that switch myself onto my 817. It explains why the older tube NDCC tire is on a 923.
I thought they went away from the NDCC at the model change. It may have been the military that made the change also, to keep their favorite 809 series with new shoes.The same wheels and tires were also OEM on early 939a0 trucks. I saw some go recently at auction with the NDTs still in place and no ABS. I'm willing to bet this is one of those trucks.
If the dash has the ABS, then the truck had G177's at some point.I thought they went away from the NDCC at the model change. It may have been the military that made the change also, to keep their favorite 809 series with new shoes.
And sure, I see your point about the ABS. They could be OEM if no ABS, but with ABS they probably had radial (could have been) changed out.
Would there be an issue using 16.00 without ABS? Or for that matter 395's?
The 939series trucks include multiple sub models, of which the M925 is one.I tried sending you a link to the rims I found below, but I guess it wont let it post. Do you have any idea if they would work for me. Do I have M939 or M925?
You have a M925A0 which is from the family series of M939's. I used 809 series when I referred to the generic series of truck, which was my first dump, an 817. The 809 series (my 817 dump) had the lug type Non Directional Cross Country (NDCC), bias tires. I'll add a picture in another post.I tried sending you a link to the rims I found below, but I guess it wont let it post. Do you have any idea if they would work for me. Do I have M939 or M925?
The tires aren't an issue. The lack of ABS is an issue with any choice of tires.no ABS light on my dash. So I take it mine doesn't have ABS, is that going to be a big problem if I put these big super singles on?
