1985 Humvee VIN / Engine number location
DREDnot
434
Phoenix, AZ
It will usually be found on the data plate in the drives door jamb
Not a full VIN like on normal cars. Just the "manufacturers serial number" Six digits long
Barrman
1,626
Giddings, Texas
The engine number is on the drivers side of the "shelf" the transmission bolts to. Find the oil pressure sender at the back of the engine and look down. It is between the peak of the triangle and the upper most driver side transmission bolt.
