1986 M998 Fuel injectors
papakb
351
San Jose, Ca
Does anyone on the forum have a recommendation for the fuel injectors used in a 6.2 engine and a known reputable vendor?
LouWon
24
Michigan
From past experience, I had mine cleaned and tested for $300.00, I was had, I don't even think they did the work, so I bought 8 refurbs, still the same , I returned them, finally went on fleebay and got 8 new BOSCH, should of done this in the first place, just look, make certain that they are the real ones, not the generic type, spend $300.00 the first time and be done, also replace the return lines, again buy quality hose.
You either have long or short ones.
Thumper580
53
Virginia
Do you remember the Bosch part number??
LouWon
24
Michigan
It depends on if you have the short or long ones
Measure from the head surface to the underside of the nut - approximately 1.5 inches on short injectors, 2.75 inches on long injectors
Part # 0432217092
CAV/Delphi# 6703801, OEM# 14063606, OEM Alt# NA51
