jwaller
- 19
- 38
- Columbia, SC
so did you ever find out if the 1 hole or 2 hole injectors were better and which one were supposed to have in the deuce?
my intention was not to slap 5 ton injectors to my deuce but to find out exactly what my deuce should have in it. if I could put the 5T inj's in and make some extra hp then so be it but for now I wanted to get the right inj's for my motor as I've heard that the depot would just throw in whatever was laying around.G744 said:5-ton injectors have one hole. 2.5 ton injectors have two holes. The fuel delivery is different and so in the spray pattern, among a hos tof other things.
The 5-ton engine also has differnt pistons, AND MOST IMPORTANTLY different "oil squirt" piston cooling nozzles to keep the fire deck temperature below critical range at load.
They LOOK the same, but you cannot just start putting parts on and expect it to run properly for any length of time.
Check my post "Paging Dr. Foster", maybe you can buy enough engines to keep your truck running for a bit.
dg
