gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 749
- 113
- Cincy Ohio
Thanks for those pictures.Well good to learn something new each day. Thanks to Cranetruck for the pic. Looks like a two piece fitting that is crimped. Once on the inner and once on the outer maybe?
Now it was said you could get a new fitting and cut a 1/4'' off the line but even if you could cut the line at the fitting you are loosing 1/2'' of injector line not 1/4'' so if all the lines need to be equal would the 1/2'' make a difference. I don't know but before I did the cut thing I would look for a new /used line myself.
Your right to a point. Technically fluids do not compress. In reality they do a little. If you have a closed line 4ft long and a line 2ft long and a metered amount of pressurized fluid injected into them will the end pressure be the same ? In a perfect world the answer would be yes. In reality there will be a slight loose of pressure in the longer line. Now add to the fact that at the end of the line is a metered orifice with a set spring pressure that must be overcome. Now we must look at the time factor. How long does it take the fluid to travel the different lengths of line ? Since the engine timing of a diesel corresponds with the injection and then firing of the fuel. So if it takes less time to travel the distance of the 2ft line what will happen to our engine timing ? We will get an early firing cylinder with a slightly higher charge of fuel, which in turn will cause loss of power and added stress to the engine. So the answer to your question is, if you take 1/2" of one line then you must take 1/2" off all the lines.Why would line length matter? It's fluid pressure. I could understand if it was a viscous material here, but it's not. A 1/4 inch or an inch isn't going to make a difference in my opinion besides when the lines are empty. It's positive displacement right?
.25" OD X .062" ID = .094" wall thickness.At times it is easier to search for parts with the FSN 4710-177-8648
and/or the part 11641781 (19207)
I usually end up at Part Target and eBay amazon places.
http://www.parttarget.com/4710-00-177-8650_4710001778650_11641781.html
TM says replace it
TM 9-2815-210-34P page 52
tube assembly,metal:fuel injector pump to fuel injection nozzle cylinder NO. 2
Fuel lines are old school and robust at .250 OD and .0625 ID
View attachment 577532View attachment 577533
That does not quite sound right.
