jbayer
- 10
- 18
- St. Aug., FL/ McGrady, NC
I rounded up. I kinda thought the .00025" to be insignificant..250-.0625=.1875/2=.09375
I've posted my findings related to just replacing the bite fitting multiple times here on the forum, but is is regularly dismissed as an option by most people. Why, I'm not really sure. Seems people want to just replace the lines at what, $75 vs. using a $1 fitting. To each his own, I suppose. I'm familiar with pressure loss over long lengths of line, but like you said, it is more than likely irrelevant here.Your right to a point. Technically fluids do not compress. In reality they do a little. If you have a closed line 4ft long and a line 2ft long and a metered amount of pressurized fluid injected into them will the end pressure be the same ? In a perfect world the answer would be yes. In reality there will be a slight loose of pressure in the longer line. Now add to the fact that at the end of the line is a metered orifice with a set spring pressure that must be overcome. Now we must look at the time factor. How long does it take the fluid to travel the different lengths of line ? Since the engine timing of a diesel corresponds with the injection and then firing of the fuel. So if it takes less time to travel the distance of the 2ft line what will happen to our engine timing ? We will get an early firing cylinder with a slightly higher charge of fuel, which in turn will cause loss of power and added stress to the engine. So the answer to your question is, if you take 1/2" of one line then you must take 1/2" off all the lines.
After thinking about this for a few minutes I reconsidered my last comment. If our lines are on average 3ft long then 1/2" is just a small percentage of that. So I don't think it will be much of a factor in the engine timing.
Could it be because it is your option. In post 33 you said cutting off one inch would not make a difference. I don't know if 1/4'' would but one inch would tells me something about your options.
If your injector lines were as rough as mine were you would understand.I've posted my findings related to just replacing the bite fitting multiple times here on the forum, but is is regularly dismissed as an option by most people. Why, I'm not really sure. Seems people want to just replace the lines at what, $75 vs. using a $1 fitting. To each his own, I suppose. I'm familiar with pressure loss over long lengths of line, but like you said, it is more than likely irrelevant here.
And with these trucks being what they are, a 1/4" which is what i took off the lines, isn't going to make a bit of difference as far as I can tell. My calibrated seat of the pants dyno. These aren't formula one race cars. Further, if one fitting is bad, as in my own experience, the others aren't far behind it in failure. Might as well cut the tubes change all the fittings, and then you have the same length lines again, making this all a mute point and you know there won't be any IP leaks like this.
The injection lines are made from a high grade alloy steel. They will flex (slightly) and still hold very high surging pressures. You can't just go to Home Depot and pick them up. So if one of mine cracks or breaks at the end I will replace it. Now if I was on the road somewhere I would try and replace the ferrule and get out of there. I plan on buying some "Parker Bite Ferrules" to keep on the truck just in case.If your injector lines were as rough as mine were you would understand.
On a side note the injector lines I bought were made from a way tougher steel tubing than the old ones. I busted 3 really good tubing benders trying to adjust the lines. They didn't line up perfectly.
I got mine from white owl. They were new manufacture. I liked the new lines. They were very nice quality. Just some of the bends weren't perfect. They were very close though. But the tubing they were made of was very strong.The injection lines are made from a high grade alloy steel. They will flex (slightly) and still hold very high surging pressures. You can't just go to Home Depot and pick them up. So if one of mine cracks or breaks at the end I will replace it. Now if I was on the road somewhere I would try and replace the ferrule and get out of there. I plan on buying some "Parker Bite Ferrules" to keep on the truck just in case.
Jake, where did you buy new lines from ? All I ever heard of was NOS which is still the OLD lines not the new stuff used in todays trucks.
The point was a 2% change in length won't affect timing. The IP is still sending pulses of fuel in the correct time. This isn't direct current. It's more akin to alternating current. The fuel that the IP shoots out on a given injection event isn't all going into the engine. It is displacing an equal amount of fuel at the far end of the line. When you change the line by 2% you change the timing and fuel delivery by even less than that. The point many are trying to make is that there is not enough loss in precision of the fuel injection to have any measurable affect on the motor performance.How and what would you use to cut the old off, taper the end and install when on the road?
I might not be the smartest man but Fact is timing is everything in life and on any gas or diesel motor. Not enough and it does not perform as well as it should. To much and bad things happen. Fact if every cylinder has the correct timing and mix they perform. With todays electric injection on gas motors we can control every cylinder duration and volume and produce the same temps in every cylinder and make them all run the same. If I was going on a cross country trip on a time table maybe I would worry and maybe carry 6 NOS lines but for the 100 miles I might be from home base or local driving I will get it home or go get my 816 and tow it home.
Now 2% was said what 1/4'' might be but can anyone tell me how many degrees that might be if any.
One inch or half inch or maybe a quarter inch the fact is it controls timing.
Put in the vise and chuck up a #2 combined drill and countersink (#2 centerdrill) and use cutting oil and touch it a bit. A 1/4" drill motor spins it fast enough. That does a nice job................ if you cut the lines what would it take to get the slow taper in the end like the stock end is. I don't have a machine shop or a proper jig to hold the line to replace the taper in the end?
I know injector lines are tough steel to begin with but I could still bend them. The new ones were much more difficult to tweek.[/QU
How difficult are they to change? I've been replacing my airlines and brake lines and have looked at mine and thought....hmmm, they are looking pretty ratty. May be time....lol. Anything else I need to replace while I'm there? The previous owner of my truck replaced the HH O-rings and cleaned and re-calibrated the injectors just a couple years ago.
If I remember correctly white owl was just under $50 per line. Csi truck parts was in that ball park also.K, thanks for the heads up. What does a new set of injector lines run? Wondering if I should put it on my "to get when I can" list so I have them when needed.
