springer1981
- 1,184
- 93
- Maine
There are a couple version of this speedometer. In the back you see dip switches that can adjust this one for compatibility. There is also one without dip switches and correct part number that should work with the OEM sending unit. I made a twisted pair signal cable and ran it from the sending unit to my dash. Added 24vdc and a light and she is ready to try. I haven't had a chance to try it since I installed it. Total install was probably less than $100 but I already had the sending unit. I think I still have the part number and there were a few on epay when I was looking.My new M1152 has a mechanical speedometer installed. I thought all M1152's had the electric 80mph speedo's installed. Was this an upgrade done later on? I have found the kit for the whole setup, part number 57k4882. And has anyone tried the Oshkosh LVS speedo, I looks the identical.![]()
