2009 vin info thread
Diamondjim11
Sunbury,Pa
Vin info
Mr Carnac,
If you can help me with this it would be a big help.
VIN 952412688
next number down on plate 5E9178
1968 Kaiser Jeep
5 Ton tractor
bought from Coleman Surplus Pa.
rebuild at LEAD 10/86
bumber numbers(what is left) pass side DCNG TPCM drivers side 13 C(?) CM_ 12
That is all I can find.
Thanks for trying.
Jim
JCKnife
46
Kentucky
I'm going to attempt this but I don't fully understand the difference between a serial number, a VIN and a registration number. I'll attach pictures of my data plates.
a. serial # 21785
b registration # 04H13471
c. NSN # 2320000771616
d. bought at Boone National Guard Center, Frankfort, KY (it's still there)
e. I don't know any bumper numbers
Copied from OP for my reference:
a. Serial Number (VIN number) ------without dashes or spaces (0123456789 correct, 0123-456789 incorrect)
b. Registration Number -----also without dashes
c. NSN without dashes -----uh, one more time, without dashes
d. Where you bought it
e. Bumper numbers if you can legibly read them
CARNAC
The Envelope Please.
670
Corpus Christi, TX
ORD service # 8736853
ID # 05E-21971 C137 10219 (might be 18219)
FED stock # 2320-050-8905
contract # DAAE06-69-C-0009
M813A1 W/W
Organization:1ST BN 119TH FIELD ARTILLERY BTY C 155 SP Location:ALBION
MICHIGAN
Nomenclature:
TRUCK CARGO D/S 5-TON Model:
M813A1 W/W NSN:
2320000508905 Serial Number:
C13710219 Registration Number:
5E21971 Year of Mfg:
1971 Manufacturer:
65909
Usage Miles: 24454
Aug 09
CARNAC
670
Corpus Christi, TX
M109A3
stock # 23200771636
serial #4h4868
MFR # 013211438
Year on data plate: 1966 Kaiser-Jeep also has a FT. Hood rebuild tag on the transfer case.
Thanks for your help
Organization:
6TH BN 33D FIELD ARTILLERY HHB
OKLAHOMA
Nomenclature:
TRUCK VAN SHOP Model:
M109A3 NSN:
2320000771636 Serial Number:
13211438 Registration Number:
4H4868 Year of Mfg:
1966
Usage Miles: 24228
Nov 04
CARNAC
670
Corpus Christi, TX
M35a2
nsn 2320000771616
sn 05251770904a80171
bumper#'s 272 rsg, 24g tc bn,14go tc, 602
Picked up at Lansing,Mi.
Thanks Joe
Organization:1460TH TC CO MDM TRK Location:MIDLAND
MICHIGAN
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 NSN:
2320000771616 Serial Number:
52517709 Registration Number:
4A80171 Year of Mfg:
1971 Manufacturer:
65909
Usage Miles: 19547
Mar 08
CARNAC
670
Corpus Christi, TX
VIN C22811041 (Maybe 022811041)
REG NL076J
NSN 2320000508913
WHERE French Camp, CA - I think
BUMPER No Bumper #s
Thanks.
Organization:
1ST SQDN 18TH CAVALRY HHT DIV CAV
CALIFORNIA
Nomenclature:
M813A1 NSN:
2320000508913 Serial Number:
C22811041 Registration Number:
NL076J Usage Miles: 99931
Sep 04
CARNAC
670
Corpus Christi, TX
M1009
VIN - 1G8ED18J9EF148515
Picked up at Jefferson City, MO.
Would like to know some info on this vehicle...
Thanks in advance!
Organization:175TH MILITARY POLICE BN HHD Location:COLUMBIA
MISSOURI
Nomenclature:
TRUCK UTILITY 3/4TON Model:
M1009 NSN:
2320011232665 Serial Number:
J9EF148515 Registration Number:
NF03JV Year of Mfg:
1984 Manufacturer:
93219 Contract Number:
DAAE07-82-C-4060
Usage Miles: 35186
Sep08
CARNAC
670
Corpus Christi, TX
Great and Mighty Carnac,
another humble submission:
1968 Kaiser-Jeep M35
vin 04H8076032521127
Title says gasser M35, dataplate says m35A2, and it is a multi.
BTW can you divine shelters as well?
Thank you.. donations forthcoming, along with some others i am late on.
Not much info
Unit Ident Code:
W3EA23 Nomenclature:
M35A2 NSN:
32521127 Registration Number:
4H80769 Year of Mfg:
1969
Sep05
CARNAC
670
Corpus Christi, TX
Mr Carnac,
VIN 952412688
1968 Kaiser Jeep
5 Ton tractor
Thanks for trying.
Jim
Not much info on this one either
Unit Ident Code:
WTXEAA Nomenclature:
TRUCK TRACTOR 5-TON Model:
M52A2 NSN:
2320000559260 Serial Number:
952412688 Registration Number:
5E9178 Year of Mfg:
1967
Sep05
CARNAC
670
Corpus Christi, TX
a. serial # 21785
Organization:103RD CS BN CO B MAINT Location:FRANKFORT
KENTUCKY
Nomenclature:
M35A2 NSN:
52521785 Registration Number:
4H13471 Year of Mfg:
1971 Manufacturer:
65909
Usage Miles: 55507
Aug 87
JCKnife
46
Kentucky
Thank you CARNAC! I made a donation to your cause.
Can someone tell me what manufacturer 65909 means?
Nevermind I see the link in the OP to find it.
36
20
Douglasville, GA
Many thanks!
Serial/ID: 042512496
Reg: NKOC5N
NSN: 2320000771616
Warner Robins
Bumber#: 310ESC 206RSG
GL Reported VIN# as NKOC5N042512496
Hoping the VIN was reported correctly b/c I just rec'd my SF97 and ins. policy with that VIN#. If not, YIKES!
CARNAC
670
Corpus Christi, TX
Many thanks!
Reg: NKOC5N
NSN: 2320000771616
Warner Robins
I'll get your vehicle info later but say YIKES. I have this posted in many places. The VIN = serial number only. The GL reported vin is inaccurate and includes the registration number and serial number combined. There is no direct correlation between a military registration number and civilian. It is worthless except for personal historical reasons.
Also you used an O (oscar) instead of a 0 (zero) in your post here. That is a second no-no. The military does not use O and I in registration numbers and serial numbers. It's always a 0 (zero) or 1 (one).
Will they give you a rash of crap over this issue, probably not. In court you could prove the point of what happened but in reality vin = only the serial number.
36
20
Douglasville, GA
At this point I wonder if I am better off to try to get the SF97 changed or to try and get my VIN verification done by an LEO and convince him the VIN is both numbers. One or the other has to match to get my state title. Suggestions, anyone?
CARNAC
670
Corpus Christi, TX
Many thanks!
Reg: NKOC5N
NSN: 2320000771616
Warner Robins
Organization:HEADQUARTERS, 733D MAINTENANCE CO Location:CANTON
ILLINOIS
Nomenclature:
M35A2C NSN:
2320009260873 Serial Number:
42512496 Registration Number:
NK0C5N Year of Mfg:
1969
Usage Miles: 3573
Sep 04
Diamondjim11
Sunbury,Pa
Vin Info
Unit Ident Code:
M52A2 NSN:
5E9178 Year of Mfg:
1967
Sep05
Carnac,
Thanks for the fast response, and please forgive my lack of knowledge:oops:. I was wondering what is the unit ident code and is there a way to break it down or research it? Thanks again
JIm
CARNAC
670
Corpus Christi, TX
Carnac,
JIm
Probably not. I found on the net a 9th MP out of the PA Army National Guard out of Johnstown PA with that UIC. Normally they aren't easy to find on the net if they aren't already on the info I post. This maybe the unit the vehicle was with but I would not bet the farm on it. All it takes is for private snuffy to fat finger a button wrong the it throws the who outcome out of whack. Once that happens it is virtually impossible to find the correct info.
Tnrobocop
Mobile, Alabama
1985 M1009 (Manufacture Date: 08/1985
a. Serial Number (VIN number): 1G8ED18J9FF211775
b. Registration Number: NFOEH7
c. NSN without dashes: 2320011232665
d. Where you bought it: From a guy on Ebay. I think he got it from Redstone Arsenal GL.
e. Bumper numbers if you can legibly read them: 933rd MP Company, Chicago,IL , IL ARNG.
Also saw HQ20 and XO markings under the paint.
Thanks.
