Jump Start
- 0
- 16
- Rockwell, NC
Plan to be at the rally on Saturday I have several 55 gal drums of pure mineral oil wondering if anyone would be interested in a drum for $2.00 per gallon
Too bad they are not Michelin XL's on Deuce Rims...Still looking for 3 more...have eleven 11x20 radial g177 tires 95%, on 5 ton rims that i'm bring to rally. anyone interested pm me or they will be there. Thanks Steve
how tall are they ?have eleven 11x20 radial g177 tires 95%, on 5 ton rims that i'm bring to rally. anyone interested pm me or they will be there. Thanks Steve
Is this the same as gl1 90 weight. If so I am interested in one.Plan to be at the rally on Saturday I have several 55 gal drums of pure mineral oil wondering if anyone would be interested in a drum for $2.00 per gallon
When you get in the gate to check in, I will be making name tags. I'd like to check out the cases, especially the medboxes.Pelican cases (briefcase style) $35 each
Pelican cases w/ lots of First Aid gear, quick clot, etc $75 each
Got everything loaded up, should be there by noon tomorrow. Here is my final list of items I'm bringing. Crew cab isn't finished, cucv has a cracked head, and no plans to drive the 936a2, so I'll be in a Tacoma with a trailer full of pelican cases loaded w/ gear![]()
200 Alice packs, large and small, no frames. $4 each, or 6 for $20
Alice packs w/ frames, only got 3 or 4, $10 each
2 Molle Packs $25 each
2 MRAP Memory foam Blast Seats w/ Integrated 5 point harness $400 each (new)
24v Humvee 10 million CP Spotlights w/ magnetic base $45 each (new, US made)
24v Golights (wireless) $300 each (new)
12v Golights $200 each (new)
Grote LED M series tailights $10 each (Scratch and dent, but they all work)
Deuce soft top $200 (new)
50ft slave cables w/ carry case $550
1" cable w/ looped ends, approx 6' long $15 each(makes great safety chains when using a tow bar)
1" cable w/ eyelet ends 10' long $20 each
Misc 1" and smaller pins $3 each
Deuce lug nuts (right) $1 each, or 6 for $5 (new)
Bridge stakes, can be used for ground rods $20 each (new)
Red reflectors for deuces, trailers, etc $2 each (new)
Digital LED light switches for M series trucks $100 (used), $150 (new)
I think that's all, trailer is FULL!
Will also have a M35A2/A3 8" lift kit by BlackRock Fabrication on display for everyone to check out.
Also bringing a few guns and suppressors (not for sale), as I think someone mentioned a range? Integral suppressed 10/22, suppressed HK MK 23, suppressed S&W 15-22, and a suppressed Walther P22. Few hundred rounds as well if someone wants to check them out.
