2011 vin info thread
wsucougarx
68
Washington State
Hi CARNAC, I secured a newly rebuilt M105A2 Cargo Trailer. The dataplate is lacking MANUF, Year of Manuf, and Reg #.
a. Serial Number (VIN number) -- PC03DA867
b. Registration Number -----nothing listed
c. NSN without dashes ----- 2330001418050
d. Where you bought it ----- JBLM (formerly Fort Lewis, WA)
e. Bumper numbers if you can legibly read them--- 62 MED BDE HHC-41TC
DonFDNY
Long Island/New York
1993 M35A3
NSN 2320013832047
Frame 222793L79n
Vin 502067
(purchased from) Lothian, MD
HQ 132 is painted on the inside of the hood.
Any history would be great!
Thanks,
Don
IROC99
Marion/South Carolina
Thanks Carnac, I received email withsome info on two CUCV 1009 from 177 AR from you. I am trying to learn how to communicate on this site efficiently, etc, but am unsure of some things. I was expecting a two week turn around on the info from you. Is that correct, or was that email it? Is there a way to get maintenance records etc?
Thanks, IROC99
CARNAC
The Envelope Please.
670
Corpus Christi, TX
Thanks, IROC99
Post #138 on this thread is the information on the vehicles you requested. Sometimes I can do it quick. Other times I can get it done real fast like the past few weeks I;ve replied within a day or two.
I provide the vehicle information for the last recorded Army user. Most maintenance records are erased from the maintenance system once the vehicle leaves the unit. The Army maintenance computer system does not have a historical file capability. Once a fault is fixed, it's dumped from the memory.
Conceivably you could contact the unit and see if they still have anything. You would have to do the research on their phone numbers and contacts on your own.
CARNAC
670
Corpus Christi, TX
M49A2 w/w
a. Serial Number (VIN number) ------ 062512640
b. Registration Number -----not sure
c. NSN without dashes ---4730009364584
d. Where you bought it- I think it came from GL in Alabama but i got it from a public auction
e. Bumper numbers... -----
some number i found on the data plate 37625269032811113 couldn't make out what it said the number was
No information on these numbers. If it is an M49A2C then the correct NSN would be
TRUCK, TANK, FUEL SERVICING, M49A2C WITH WINCH (2320-00-077-1632) (EIC: BMF)
If this is an original M49A2C w/w (winch not added after the fact) then it is indeed a somewhat rare bird.
There also a good potential this truck was used by the USAF and I wouldn't have records on that.
CARNAC
670
Corpus Christi, TX
Organization:HHC, 62D MEDICAL BRIGADE Location:FT LEWIS
WA
Nomenclature:
TRLR CARGO (1-1/2T) Model:
M105A2 NSN:
2330001418050 Serial Number:
PC03DA867 Registration Number:
PC03DA Year of Mfg:
1985 Manufacturer:
3K099 Contract Number:
DAAE07-83-C-H309
Aug 85
CARNAC
670
Corpus Christi, TX
1993 M35A3
NSN 2320013832047
Frame 222793L79n
Vin 502067
Thanks,
Don
Organization:373D MEDICAL DETACHMENT Location:BLACKLICK
OH
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M44A3 NSN:
2320013832047 Serial Number:
502067 Registration Number:
NK0J2L Year of Mfg:
2006 Usage Miles: 6190
Sep 2010
Hooty481
Russell County Kentucky
thanks CARNAC... the vin plate thats in the truck is the one the the GL issued the title for but it doesn't look like it ever had a tank or a winch on it... prob just a plain jane m35 with a rare vin plate
jamaral
san jose Ca
M35a2
I need some help! I recently bought a Deuce and Half from Gov. Liquidators. I'm still waiting for the EUC to clear. They have no year or make on the Deuce. This is the only info I have see below. This Army veteran would appreciate anyone's help.
M35A2
SN#04H67871052522177
NSN#2320000771617
CARNAC
670
Corpus Christi, TX
Get the serial number off the frame. That will straighten this out...we hope. Post #1 gives the info on where to find the number on the frame.
Good luck
M1075
Oklahoma City
Can you help with my M870A1 trailer?
a. Serial Number (VIN number) ------ S/N 551814 is etched on gooseneck
b. Registration Number -----WRYAC0
c. NSN without dashes -----2330012249245
d. Where you bought it ------private seller
e. Bumper numbers if you can legibly read them ---- 65RRC 448E (left) and DOO35 CT243 (right)
mikey
39
Lake Como, PA
a. Serial Number (VIN number) ------without dashes or spaces (0123456789 correct, 0123-456789 incorrect)
b. Registration Number -----also without dashes
c. NSN without dashes -----uh, one more time, without dashes
Deuce1:
a. 022515688
b. 4k3412
c. 23200771617
d. gl - mechanicsburgh, PA
e. none
Deuce2:
a. 032526318
b. 04a29870
c.
d. gl - mechanicsburg, PA
e. none
CARNAC
670
Corpus Christi, TX
M35A2
NSN#2320000771617
Organization:US ARMY RESERVE COMMAND G4 EXCESS EQUIPMENT Location:FT MCPHERSON
GA
Nomenclature:
M35A2 NSN:
2320000771616 Serial Number:
52522177 Registration Number:
4H67871 Year of Mfg:
1970 Manufacturer:
65909 Usage Miles: 23950
Info as of Aug 98. The year says 1970 but the registration number tells me 1971. I personally would go with 71. The database is inputted by lower enlisted clerks so basically garbage in, garbage out.
CARNAC
670
Corpus Christi, TX
Heres a 66:
A 4K1897
B
C 2320000771616
D Mechanicsburg, PA
E
Organization:USPFO TRANS ACTIVITY PA A Location:FT INDIANTOWN GAP
PA
Nomenclature:
M35A2 NSN:
22514770 Registration Number:
4K1897 Year of Mfg:
1966 Usage Miles: 31989
Sep 04
CARNAC
670
Corpus Christi, TX
I didn't find anything. The WRYAC0 is actually a unit identification code. I was able to find it and it is C Company 448th Engineer Battalion, 65th Reserve Command (now known as the 1st Mission Support Command) located in Ft Buchanan, Puerto Rico. Your trailer is a long way from home. Give it a sip of rum, it'll be ok.
The serial number should start off as a 100, 101, or 102 and then 4 additional digits.
CARNAC
670
Corpus Christi, TX
Deuce1:
a. 022515688
b. 4k3412
c. 23200771617
e. none
Deuce2:
a. 032526318
b. 04a29870
c.
e. none
Organization:W7NX USPFO TRANS ACTIVITY PA A Location:FT INDIANTOWN GAP
PA
Nomenclature:
M35A2 W/W NSN:
2320000771617 Serial Number:
22515688 Registration Number:
4K3412 Year of Mfg:
1971 Manufacturer:
65909 Usage Miles: 59960
Jan 96 it was sent to D Co 1st Battalion, 103rd Armor Battalion in Connellsville, PA.
PA
Nomenclature:
M35A2 NSN:
32526318 Registration Number:
4A29870 Year of Mfg:
1970 Manufacturer:
65909 Usage Miles: 11889
Mar 08 data
