2013 Drash Deere 3029T Genset
trsnider
Va. Beach Va
Hello,
I’m working on a genset with the 3029T Deere motor, units has 300 hrs and the ring gear is missing teeth and the starter has to nose snapped off, replacing ring gear is no sweat. But the starter is aftermarket as it has a tag from diesel shop and I got to thinking maybe someone got the wrong starter.
so I was kinda hoping someone might know a part number for the ring gear and starter. I would also love to find some tech manuals for this unit. I’m gonna attempt to post a tag picture 😁
I appreciate the time and help
I’m happy to help with electrical / electronics if I can be of use to anyone
thanks
Tony
818EB450-23C3-4668-BAE9-C05D91866C22.pngBF8A9D4C-6143-46CB-8437-B3AD5D70DFAB.jpegAE04FC12-0686-4E61-9585-F8A5F852E215.jpeg7E60508B-A445-4FE9-8EBE-C3CD91E27E59.jpeg
Guyfang
22,274
Burgkunstadt, Germany
If you want to know something about the gen set, you need to provide the model number. If you want to know something about a JD engine, I would get in contact with JD.
This looks like a HDT 35 KW with a 8 ton ECU
The starter MIGHT be, 2920-01-533-6908
The part # MIGHT be 3000301-001
For the ring gear, you need a JD part book
Call HDT
Poccur
97
Roanoke, VA
Hello,
thanks
Tony
Hey Tony,
Did you get this resolved? I have the manual, PM me and I will help you with the part numbers also..
