2014 VIN Info Thread
mkcoen
381
Spring Branch, TX
1991 BMY-Harsco M923A2 Cargo Truck
A. 2305782
B. NL137J
C. 2320012300307
D. GL San Marcos, TX
E. 36 -1 4/133 (right side) C76 ( left side)
The truck appears to be a rebuild but no rebuild tag. Engine tag identifies it as a 2009 engine and all batteries were stamped 2009.
m715mike
3,884
Montgomery, Texas
Carnac,
Would you please take a look at my M105A2 trailer (year unknown):
a. PC05UR1181
b.
c. 2330001418050
d. GL Red River Army Depot
e. 335 SIG (left) CM 32T (right)
There is a small plate near the data plate that reads "Reworked by VSE Corporation 2/11."
Any information is much appreciated.
-Michael
Edit 5/23/14 - Donation made. Thank you very much Carnac!
uwrugby
Yakima,WA
Thank you for doing this. You can count on me for a donation
1966 M185A3 Deuce and Half Van
Serial 4K0642
NSN 49400771638
Bought from private party who bought from Marine Corp Logistics Base in Barstow, CA ( I believe)
If it helps the MFR # is C23010097
Mfg Kaiser Jeep South Bend Indiana
Says MOD SH-D-54
I believe it is Army
Thank you
SuperCub
Louisiana
Help if you can , Thanks
M35a3 wo/w
Serial #:502633
Registration #
NSN #:232c013832047
Where bought:Ft.Polk,LA (GL)
Bumper Numbers 259th ATCS
Thanks again John
CARNAC
The Envelope Please.
686
Corpus Christi, TX
Info for my 1985 CUCV Blazer
a. 1G8ED18JXFF102886
b. NF074L
c. 2320011232665
d. Private sale from owner in Auburn, Alabama. He bought from GL.
e. Left = 1-AE/157INF Right = 1/349 28
Organization: 1ST BATTALION 349TH REGIMENT
Nomenclature:TRUCK UTILITY 3/4TON Model:M1009 NSN:2320011232665
Serial Number:1G8ED18JXFF102886 Registration Number:NF074L Year of Mfg:1984
Manufacturer:93219 Contract Number:DAAE07-82-C-4060
Info May 1996
CARNAC
686
Corpus Christi, TX
M51A2 W/W (dump) w/ LDS465
a. 512312382
b. None
c. 23200559263
d. Local Municipality
e. None
Overhaul tag USA-MP BOEBLINGEN - MAR 73
No unit but I do have a unit code:WRJYAA. You might be able to dig the unit info off the internet.
Nomenclature:TRUCK DUMP 5-TON Model:M51A2 W/W NSN:2320000559263
Serial Number:512312382 Registration Number:5D7839 Year of Mfg:1965
Manufacturer:65909
No info on when the last update occurred.
CARNAC
686
Corpus Christi, TX
Carnac,
a. PC05UR1181
b.
c. 2330001418050
-Michael
Organization: DCMC SEATTLE-PORTLAND
Nomenclature:TRLR CARGO (1-1/2T) Model:M105A2 NSN:2330001418050
Serial Number:pC05UR1181 Registration Number:pC05UR Year of Mfg:1987
Manufacturer:62239 Contract Number:DAAE07-86-C-J042
Info NOV 1987
CARNAC
686
Corpus Christi, TX
Serial 4K0642
NSN 49400771638
Says MOD SH-D-54
Thank you
Organization: 140TH AV CO F Location: LOS ALAMITOS CA
Nomenclature:INST RPR SHOP TRK MTD Model:M185A3 NSN:4940000771638
Serial Number:23010097 Registration Number:4K0642 Year of Mfg:1966
Manufacturer:65909
Info Sep 2005
CARNAC
686
Corpus Christi, TX
A. 2305782
B. NL137J
C. 2320012300307
Organization: BATTERY C 4TH BATTALION 133RD FIELD ARTILLERY REGIMENT
Location: CORPUS CHRISTI TX Nomenclature:TRUCK CARGO D/S 5-TON Model:M923A2 NSN:2320012300307
Serial Number:2305782 Registration Number:NL137J Year of Mfg:1991
Manufacturer:47457 Contract Number:DAAE07-86-C-J111
Info July 2009
CARNAC
686
Corpus Christi, TX
M923A2 Cargo Truck
A. 2302703NL0UEV
B. Unable to locate.
C. 2320012300307
D. Camp Grafton, Devils Lake ND.
E. 3662MC (right side) M082 ( left side)
Delivery Date Feb 12.
Organization: 3662D MAINTENANCE CO Location: CP GRAFTON ND
Serial Number:2302703 Registration Number:NL0UEV Year of Mfg:1990
Info March 2013
CARNAC
686
Corpus Christi, TX
1984 M1009 CUCV
a. 1G8ED18J5EF123949
b. NFO2SD
c. 2320011232665
d. FT Hood area.
e. HQ 820 stenciled inside doors.
Thanks for what you're doing Carnac!
Organization: US ARMY OPERATIONAL TEST COMMAND Location: FT HOOD TX
Serial Number:J5EF123949 Registration Number:NF02SD Year of Mfg:1984
Info Aug 2006
BTW: You owe triple for failing to read instructions. You used an O instead of a 0.
CARNAC
686
Corpus Christi, TX
M936A2 W/W Wrecker Truck
A. 36700497NL0BYW.
C. 2320012300304
E. D1-188ADA (right side) D3-123 (left side)
Delivery Date blank.
Organization: DET D, 1ST BN 188TH AIR DEFENSE ARTILLERY Location: GRAND FORKS ND
Nomenclature:TRUCK WRECKER 5-TON Model:M936A2 W/W NSN:2320012300304
Serial Number:3600497 Registration Number:NL0BYW Year of Mfg:1984
Info Mar 2010
Dozer11B
Alabama
Info Aug 2006
Dammit. Knew I would screw it up...:burn:
Donation sent and thanks for the info.
rlltide12
NW Florida
1986 M1008
a. 1GCGD34J9GF433363
b. NG2C5C
c. 2320011236827
d. Camp Shelby, MS
e. N/A
Thanks in advance!
Edit: Donation made in advance as well for a great cause!
Cedar Valley, Utah
CARNAC I hear you are the wizard when it comes to getting information on CUCVs. So, here's one for ya!
A. Serial/VIN: 1GCGD34J4EF383193
B. Registration Number: 533521
C. NSN: 2320011236827
D. Where did I get it: I bought it (currently in the transaction) from Cedar Fort fire department in Cedar Fort Utah, they got it from (I was told) Lone Peak fire department about 8 years ago, and I think Lone Peak is the one who originally bought it from the military.
E. Bumper numbers: Illegible under the numerous coats of paint from fire service. (I would LOVE this information if you can get your hands on it)
Now, as MUCH information as you can provide I would be eternally grateful. I am wanting to do a complete and accurate write up about the truck and the restoration. So, anything you can give me, I would greatly appreciate it.
Crash_AF
Colorado Springs, CO
Thanks CARNAC for everything you do around here. Wouldn't be the same without you.
1985 CUCV M1009
A. VIN: 1G8ED18J5GF104031
B. REG: NF0EX3
C. NSN: 2320011232665
D. Base: Fort Carson, CO
E. Bumper: None - repainted
CARNAC
686
Corpus Christi, TX
What can the all knowing CARNAC foretell of this CUCV?
Edit: Donation made for two! Thanks!
Nomenclature:TRUCK CARGO 1-1/4T Model:M1028 NSN:2320011275077
Serial Number:J9EF360383 Registration Number:NG14H7 Year of Mfg:1984
Info Aug 2006
It was reregistered in 2006 as a COMPACT...yes COMPACT
Nomenclature:TRK CARGO(1 1/4T-4X4) Model:COMPACT NSN:2320010907890
Serial Number:1GCHD34J9EF360383 Registration Number:CT7365 Year of Mfg:1984
Info Aug 2012
