2016 Ga Military Vehicle Rally buy/sell/trade thread
zout
155
Columbus Georgia
Looking for interior repair parts OR the center section of the retractable light reel .... needed for Doc's M170 Ambulance. See me at the Rally if you have anything. Thanks
swiss
931
Oakwood, Ga
Okay got a somewhat complete list of inventory of parts for sale at the Rally, This encompasses the following vehicles
1.) CUCV
2.) 2 and 5 Ton
3.) M35
4.) HMMWV
Get back to me via PM if you see something you have to have, if not will see everyone on Thursday.
PNDescription
8382966-2M101 Vinyl Cover Camo
4020861CUCV Transfer Case Adapter
87578095 Step Aluminum Boarding Ladder Sold
800 Series Air Pack (NOS)
CUCV 6.2 after 95 Cylinder Head
2910011500950CUCV 6.2 Injector Set (NOS)
Shifter
M880 Tow Adapter (Set)
28MTCUCV 24 Volt Starter NOS
2/5 Ton Mud Flap Set
Load Tamer Cargo Net: No Carabiners
Tent Pole Kit
CUCV Bumper
Winch Cable End
CUCV Bumper
CUCV door Passenger
CUCV Alternators Rebuilt
14038644CUCV Throttle Cable
12447175HMMWV 4L80E Transfer Case Adapter
14066255CUCV Fuel Ignition Idle control (NOS)
19168610HMMWV Water Pump 6.5 (NOS)
23500012HMMWV 6.2 Coolant Crossover
Wrecker Chains
CUCV maintenance kit
CUCV Mirrors Set
Pressure Plate
26000060CUCV Vacuum Pump
2910011500950CUCV 4 - 6.2 Injectors (NOS)
CUCV Brush Guard
CUCV Injector Lines (NOS)
HMMWV Oil Dip Stick Assembly
CUCV Power Steering Pump Assembly
66200099355462/5 Ton Oil Pressure Sending Unit
AA52508-1Battery Gauge (box only)
MS24543-22/5 Ton Temp Gauge
MS24544-22/5 Ton Fuel Gauge
2 Can Holder Assembly
Flag Bumper Mount Kit
14057219CUCV TH350 Transmission Vacuum Valve (New)
6.2 Oil Pump (NOS)
HMMWV water pump (NOS)
CUCV Front Grill
CUCV Mirror Set
HMMWV Seat
CUCV Pintle Hitch
MS24537-12/5 Ton Temp Sending Unit
660222/5 Ton 24V Starter Solenoid
10948079M35 Outer Bearing
12554488HMMWV Throttle Position Sensor
14028917MCUCV 6.2 Coolant Crossover
SP0930-95-M-1029CUCV 24v Glow Plug Relay
Tent Pole Bags
2/5 Ton 24 Volt Engine Starter Switch
10872023M35 Lower Radiator/Upper Hoses Kit
CUCV 6.2 Pulley Set
23861HPCA Solenoid
11143732/5 Ton Starter Solenoid
12338780HMMWV & CUCV Oil Filter adapter 6.2
26214CUCV Stanadyne 6.2 Shut off Solenoid (NOS)
5330-00-075-1764M35 Axle seal deuces
5930-00-898-05002/5 Ton Rotary Switch
6616CUCV Starter Solenoid NOS
6A84CUCV Glow Plug Spares
974-1215-010-09CUCV Glow Plug Relay (NOS)
MS24537-12/5 Ton Engine Temp Sender Kit (NOS)
MS-53000-12/5 Ton Dimmer Switch
TS6059CUCV Engine Temp Sender (NOS)
12 Ton Bottle Jack
HMMWV Jack
CUCV Front Shackle Mount
CUCV 3 belt kit
Transfer Case Mounts (set)
CUCV 6.2 Intake
HMMWV Intake
25036797CUCV Engine Coolant Temp Sender Kit (NOS)
Heater Control Assembly
CUCV Motor Mounts Kit
19207-8738032M35 Inner Wheel Seal
3110010308475Tapered Roller Inner
8097CUCV Power Steering Pump Seal Kit (NOS)
24 Volt Hella Lights
Battery Hold Down
CUCV Exhaust Manifolds
CUCV Fan Blades
Temp sending unit
14050445CUCV CDR Crankcase Hose (NOS)
23861CUCV Stanadyne 6.2 AIR/Fuel Solenoid (NOS)
358-1805 Ton Thermostat
3882979CUCV U joint Position Holder
55883CUCV Choke 6.2
5743751HMMWV Transfer Case Output Seal
6264100CUCV Radiator Mount Pair
Q-387AS-382ACUCV Inner Bearing
TM59ACUCV Transmission Modulator (NOS)
CUCV Jack
Jerry Can Holder
CUCV Shift Housing
Pioneer Rack - Shovel
Pioneer Rack - AX
Pioneer Rack - Maddix
CUCV 2 belt kit-alt driver/pass
2/5 Ton shift boot
CUCV Starter Bracket
CUCV Headlight Bezel
CUCV Starter Mount Bracket (USED)
Slave Adapter 2 Pin
CUCV Exhaust Doughnuts
CUCV Injector Guides (Set)
CUCV Headlight Pairs
M1008/09 Gun Mounts
6264100CUCV Radiator Mount Single
ms51915-29-2Output shaft seal
CUCV Lug Nut Spares 4 pcs
CUCV 6.2 Oil Filters
CUCV Transfer Case Ground Guard
Wrecker Boom Ground Support Assembly
3/4 " Tow Pins (NOS)
1,824
That is a ....."robust" list Swiss. $50 for everything? Depending on price, I might have to need the 28MT starter. Several other items have piqued my interest.
1,824
Awe gheez, just blew my last 5 grand on a possum incubator. Gotta save the pouch babies when momma gets hit.
Tinwoodsman
77
Comfort, Texas
Gee Swiss. You should open a parts business. I am sure you could beat some the ones that are out there. [thumbzup]
Bobcat701
Autryville, NC
I'm packing now and chopping at the bit to get up there. As I said before I am packing light and only one person has said he wants one of Hemtt air ride seat. If no one else says they would like one or at least would like to see one then I will only bring one extra. Good time to get one or two as no shipping so break open the piggy bank guys. Tanks
I would like one. I PM you last minute. Mess up here in NC, but I am cleared hot for the trip! ETA Thursday PM.
izzug
Atlanta GA
For What??? Reason I asked, just found a pretty nice used M939 5T 3 color cargo cover, rubber rope gone $200 OBO on Saturday ain't coming home
5 step aluminum ladder NOS. $100
Do you have anymore aluminum ladders? If so I'll take one. Sorry no
mdmorgan
AM3 U.S. Navy
1,085
104
Forsyth, Ga.
Swiss, I'm interested in the pioneer rack tools. The wife and I are already set up at the rally, see you when you get here.
Sent from my XT1080 using Tapatalk
wreckerman893
Possum Connoisseur
15,645
2,134
This is a recap of what I posted earlier. I think the only thing spoken for is the bolster trailer tire and rim.
I have a butt load of the OD green boxes I sold at the 2015 rally. They are various sizes (most of them are about foot locker size) and some have handles.
Some of them have minor water damage but nothing a good thick coat of OD green paint won't fix. Some of them were used to transport 9mm pistols and still have the foam rack in them. Some can be locked.
Fire sale price is 10 bucks a pop for any size. I need to move these things. They are loaded on pallets and if you want a pallet of them I may take a little less per unit.
I have two 5 ton spare racks for the super singles. One is complete and one is missing the davit pole. No chainfall with either. I'll take a hundred dollar bill for both.
I have two sets of front springs off deuces but one appears to have more leafs in it. Have some U-bolts, shock mounts and misc. hardware. Not sure if there is enough hardware for both sets. Stuff migrates around here. I'll take 150 for both sets. They are also on a pallet.
I have some of the small black mats I had at the 2014 rally. These are anti-fatigue mats but they are small.....like floormat size small. 10 bucks each. Only a few left.
I have a bunch of stainless steel containers and flat pans that came out of a mobile photography lab. These would be very useful for cheese making, candle making or any other process where you need anti-corrosive containers. They fill up a pallet and if you had to buy them you would be looking at a ton of money. 100 bucks takes all.
I have a bunch of misc. 5 ton parts that will be spread out on a table and tagged with what I think they're worth. Included are new air wiper motors, window roller mechinisms (one right, one left). There are also some of the black boxes that mount on the firewall and have a big cannon plug on the bottom. These are still sealed up. Eastern surplus sells them for 390 bucks. I'll take 300 they are still sealed in the original packing.
I still have several of the aluminum flex pipes that were used to remote generator exhaust. 5 bucks each
I'm still rooting through the storage trailer and other places so who knows what else I'll find.
Come by the "Circus Wagon" and see what I have.
swiss
931
Oakwood, Ga
I found some more items:
These are NOS
11664387Clutch Disc For 5 Ton Trucks M809 and M54A2 (M39A2) Series
8735507Pressure Plate 5 Ton Trucks M809 and M54A2 (M39A2) Series
CUCV 1010 & 1028/205 Transfer Case Shifter
M100 Landing Leg taken off my M100
