Csm Davis
- 403
- 83
- Hattiesburg, Mississippi
I would like the following if still availablem998
green Doghouse cover with insulation. One side snap intact, one missing buckle, fiberglass slightly cracked in 2 spots. Have some data plates attached. Not perfect but better than no cover. $45
2 man green cargo divider/bulkhead with 2 L mounting brackets $75
2 man green cargo divider/bulkhead with no brackets $60
2 or 4 man bows (same) $20 each- 2 available
hood stop bump pad center $10
hood stop bump by latch $10
6.2L core engine with heads, oil pan, inj pump, front cover, valve covers. No cracks or holes seen $75
Serpentine belt AC mount kit red dot $30
Rear upgraded mwo towing bumper used take off with 5/8 bolts $90
rear body to frame mount bracket $15 each
lmtv/fmtv rim with ctis hardware & hoses $85
2 395-20 XZL less than 30% tread for spare/trailer $40 each
16-20 xzl 95% tread with hole in middle of tread-needs patch and slight curb rash on sidewall. best for spare $75
m923/m925/m927 1100x20 spare tire carrier with davit complete $150
m939 blank gauge panel $30
1 only armour shackle with 1-1/2 pin/keeper $40
3/4 tow bar pins set of 2 new $25
microphone holders $4
1 only ibis tek tow bar foot medium $30
Make offer acceptable![]()
Serpentine belt AC mount kit red dot $30 thanks bud
Sent from my SM-G900V using Tapatalk
