2017 Denton Buy Sell Trade
simp5782
Feo, Fuerte y Formal
9,492
Mason, TN
Hey simp5782, are you selling the G177's singularly, or is it an all or nothing deal? I'm looking for at least one, but could take up to four.
Jeff
One deal. Working on a transaction actually. You can get em from feltz for 100 and i can drop them off.
Sent from my SM-G860P using Tapatalk
AMGeneral
116
Connelly Springs, NC
I forgot to mention in the previous post, I also have up to 10 each M34/M135 wheels, a few have junk tires, but all the wheels are serviceable with some blasting and paint.
$25 each delivered to the rally, PM me if interested.
I also have a set of NEW Napa belts(5) and Fleetguard oil/fuel filters(1 oil,4 fuel) as well as a new air governer for a M916/M920 with the 400 BC Cummins, $120 for everything.
Ford Mechanic
9
Edenton, NC
I've got a set of 14.00-20 tires on 5 ton rims going to be for sale. I'm going to be pulling them off at the rally and installing 395's. Hit me up, I'm not trying to bring them home.
Sent from my SM-G900V using Tapatalk
swiss
926
Oakwood, Ga
Here is a somewhat accurate listing of current items for sale preshow that I can deliver if purchased ahead of time. I am traveling fast and light so will only bring up what is purchased ahead of the show. If you see something you need please get with me to make an order and I can get you pictures, validate availability etc.
New Medium Towbars with 3/4" adapters included $345
New HEMTT cover kit, $650
M1008 bench seat. Great Condition. You will also get an extra NOS never installed lower bench seat bottom. Seat mount sliders included and plastic end caps. $300.00
PNDescriptionUnit Price
2 Ton 3/4 " Tow Bar Pins (NOS)$25.00
2 Ton Shear Pin Small (NOS)$5.00
11143732/5 Ton 24V Starter Solenoid (NOS)$25.00
MS-53000-12/5 Ton Dimmer Switch (NOS)$20.00
MS24537-12/5 Ton Engine Temp Sender Kit (NOS)$20.00
MS24544-22/5 Ton Fuel Gauge (NOS)$45.00
2/5 Ton Mud Flap Set with mounting$75.00
66200099355462/5 Ton Oil Pressure Sending Unit (NOS)$48.00
5930-00-898-05002/5 Ton Rotary Switch (NOS)$25.00
2/5 Ton shift boot (NOS)$10.00
MS51066RP475 Ton and 809 Series Matched Set Power Steering Pump Belt Set (NOS)$30.00
116643875 Ton Clutch Disc For 5 Ton Trucks M809 and M54A2 (M39A2) Series$75.00
87355075 Ton Pressure Plate 5 Ton Trucks M809 and M54A2 (M39A2) Series (NOS)$275.00
5 Ton Shear Pin Large (NOS)$5.00
5 Ton Snatch Blocks$45.00
358-1805 Ton Thermostat (NOS)$15.00
809 Series Air Pack Air Assist (NOS)$100.00
CUCV 6.2 3 belt kit-alt driver/pass/ps (NOS)$20.00
25036797CUCV 6.2 Engine Coolant Temp Sender Kit (NOS)$20.00
TS6059CUCV 6.2 Engine Temp Sender (NOS)$20.00
6264100CUCV 6.2 Mount Single (NOS)$5.00
CUCV 6.2 2 belt kit-alt driver/pass (NOS)$10.00
SP0930-95-M-1029CUCV 6.2 24v Glow Plug Relay (NOS)$30.00
CUCV 6.2 after 95 Cylinder Head$100.00
CUCV 6.2 Alternators Partial Rebuild$40.00
CUCV 6.2 CDR Piping$10.00
55883CUCV 6.2 Choke Used$10.00
14028917MCUCV 6.2 Coolant Crossover$35.00
CUCV 6.2 Engine Pulley$10.00
CUCV 6.2 Exhaust Doughnuts 2pcs (NOS)$5.00
CUCV 6.2 Fan Blades$10.00
14066255CUCV 6.2 Fuel Ignition Idle control (NOS)$50.00
14033953CUCV 6.2 Fuel Injection Clip$10.00
23861CUCV 6.2 HPCA Solenoid (NOS)$25.00
2910011500950CUCV 6.2 Injector 4 pcs (NOS)$30.00
CUCV 6.2 Injector Guides (Set)$10.00
CUCV 6.2 Injector Pump (core)$65.00
CUCV 6.2 Intake$25.00
CUCV 6.2 Oil Filters (NEW)$5.00
CUCV 6.2 Oil Pan Clips$1.00
CUCV 6.2 Oil Pump (NOS)$40.00
CUCV 6.2 Power Steering Pump Assembly Used$50.00
8097CUCV 6.2 Power Steering Pump Seal Kit (NOS)$10.00
6264100CUCV 6.2 Radiator Mount Pair (NOS)$10.00
26214CUCV 6.2 Stanadyne 6.2 Shut off Solenoid (NOS)$25.00
23861CUCV 6.2 Stanadyne 6.5 AIR/Fuel Solenoid (NOS)$10.00
CUCV 6.2 Starter Mount Bracket (USED)$10.00
6616CUCV 6.2 Starter Solenoid NOS$25.00
CUCV 6.2 Steering gear kit$10.00
CUCV 6.2 Temp sending unit (NOS)$15.00
26000060CUCV 6.2 Vacuum Pump (Used)$25.00
CUCV Battery Hold Down$10.00
Q-387AS-382ACUCV Bearing Inner (NOS)$10.00
6259033CUCV Brake Front Caliper Piston Seal$5.00
2230359CUCV Brake Piston (NOS)$20.00
2235039CUCV Brake Piston Caliper Boot (NOS)$10.00
6259033CUCV Brake Wheel Cylinder Piston Seal$5.00
CUCV Front Headlight Bezel$10.00
CUCV Front Headlight Pairs$10.00
CUCV Front Shackle Mount$30.00
CUCV Heater Control Assembly$25.00
CUCV Jack$10.00
CUCV Jack and Handle$25.00
CUCV Mirror Set$30.00
CUCV Motor Mounts Kit$20.00
CUCV Pintle Hitch 1008$40.00
CUCV RH Rear Taillight$5.00
1981CUCV Seal ?$10.00
CUCV Shift Housing$10.00
4020861CUCV Transfer Case Adapter (Used)$75.00
CUCV Transfer Case Ground Guard$25.00
CUCV Transfer Case Mounts (set) (NOS)$25.00
9449SKRCUCV Transfer Case Rear Seal$10.00
CUCV Transmission 1010 & 1028/205 Transfer Shifters$75.00
TM59ACUCV Transmission Modulator (NOS)$10.00
14057219CUCV Transmission TH350 Vacuum Valve (NOS)$40.00
3882979CUCV U joint Position Holder (NOS)$5.00
HEMTT Mud Flap Set$20.00
12338780HMMWV & CUCV Oil Filter adapter 6.2$25.00
12447175HMMWV 4L80E Transfer Case Adapter (NOS)$75.00
23500012HMMWV 6.2 Coolant Crossover$50.00
HMMWV Intake$10.00
HMMWV Oil Dip Stick Assembly (NOS)$50.00
HMMWV Seat Upper / Lower$40.00
12554488HMMWV Throttle Position Sensor (NOS)$35.00
5743751HMMWV Transfer Case Output Seal (NOS)$10.00
M100 Landing Leg$45.00
M1008/09 Gun Mounts$10.00
5330-00-075-1764M35 Axle seal deuces$25.00
10912423M35 Injection Pump Oil Line$10.00
19207-10896684M35 Inner Wheel Seal (NOS)$10.00
19207-8738032M35 Inner Wheel Seal (NOS)$10.00
10872023M35 Lower Radiator/Upper Hoses Kit (NOS)$30.00
10948079M35 Outer Bearing (NOS)$35.00
1088M35 Rear Main Seal Housing$35.00
10948082M35 Transfer Case Input Bearing$15.00
MISC 12 Ton Bottle Jack$35.00
MISC 2 Can Holder Assembly$45.00
MISC 24 Volt Hella Lights$15.00
MISC 5 Lug Trailer Tire$20.00
MISC Data Plates$5.00
MISC Flag Bumper Mount Kit Custom$45.00
MISC Jerry Can Holder$15.00
MISC Tent Pole Bags$35.00
MS51915-29-2Output shaft seal$5.00
Pioneer Rack - Maddix$10.00
Slave Adapter 2 Pin$10.00
3110010308475Tapered Roller (Inner?)$15.00
Wrecker Boom Ground Support Assembly-2 Uprights and Feet$200.00
Wrecker Chain 1" NOS$100.00
Wrecker Chain 3/4 Used$75.00
swiss
926
Oakwood, Ga
Questions on these items that I may be interested in:
Have any pics of these?
what is the length of the 1" wrecker chain?
I can get pictures. please PM me your phone to text pictures if that works or get me an email address
The 1" chain is 20' long it is from an M1070 and rated for 60,000 lbs plus
Jerry can holders are green and not all rusted out
CUCV Pintle hitch is a complete assembly with backing plate from an M1008 in great shape
5 Ton snatch blocks are the monster blocks
Oxyacetylene
179
Stoneville, NC
Latest WTB List:
Driver's side sugar scoop (antenna mount) for FMTV/LMTV
Winch tail chain
Antenna mast
LMTV seat covers
M1079 boarding ladder
screws that hold on the tail light covers and headlight bezel
Oxyacetylene
179
Stoneville, NC
If they are standard military tail lights I have the screws. How could you be missing them?
Yep the standard ones that are only threaded near the tip section. I am missing a couple random ones from tail lights. One of them in a front headlight bezel is different from the others and doesn't seat all the way down like I would want. Just looking to replace the couple missing and oddball ones on my truck :)
Oxyacetylene
179
Stoneville, NC
What exactly is this?
Just a generic term I used. I'm interested in extendable antenna masts. Last year I was able to get a 30' one from a member at Findlay that Ferroequinologist brought back east for me. Ideally I would like to find something in the 50' height range. The military has had a few different portable designs and a few that are better suited for semi permanent installation. I'm just putting the word out to see what folks might run across. Something portable would be cool, but I am also interested in something I could set up at home. It's mostly for my ham radio interests.
JohnJuan
Hickory,NC
14x20 at Denton
What are you trying to get for the 5 ton tires?
What kind and condition?
Instead in any trades?
Zadvark
North Carolina
I've been looking for the same thing. It's out of my league but Delk's nearby has a trailer unit complete with built-in 10KW gen sets. I'd need my 5-ton to tow it but I think it's easily a 120' tower. A 50 foot telescopic would be perfect.
swiss
926
Oakwood, Ga
Okay I will be packing up tommorow, if anybody wants any items please get back to me today to arrange and discuss.
I have the following items heading to Denton
Oxy
1.) Snatch Block
2.) 1" Wrecker Chain
3.) Jerry Can Mounts
4.) Pintle Hitch
5.) Brake Lens cover screws
Koffee
1.) 1" Wrecker Chain
2.) 3 FMTV Toolboxes
Bachman
1.) Medium towbar
2.) 4 Snatch blocks
