2017 Findlay buy sell trade
simp5782
Feo, Fuerte y Formal
9,513
Mason, TN
Tires from Feltz? I can pick up next monday and drop in the i65 i75 i71 corridor in Kentucky and ohio. As far north as detroit
Sent from my SM-G860P using Tapatalk
EMD567
Driver for the Ga Mafia
Aiken SC
Is Kip going to have a tent set up as in previous years? I am looking for a spot to crash for three nights.
av8or
fort denaud, florida
Looking for: wrecker BII. Delineators for deuce/5 ton trucks. Windshields with frames for M35A2 cab. Convoy light kits (for M816 wrecker). M809 series wiring harnesses (front or rear), bonus points for wrecker harnesses. Medium Towbar with feet. Electric windshield wiper kit for Deuce/M809 series 5 ton.
Have windshields I can bring $ 100 each. Must have an a sale or I'll not bring
Wire Fox
162
Indianapolis, Indiana
I've got an NP218 transfer case that appears to be rebuilt, judging by tags that were in its crate. It was painted green at some point. I never installed it or tested it, but all the output shafts do turn when the input shaft is turned by hand without any gritty feeling or harsh noise... I'd like $250 for this, or a good trade.
Next big item I have a NOS 200 Amp Niehoff N1228-1 ( 2920-01-458-9238 ) dual-voltage alternator that is supposed to be for an M1074 PLS truck. This may work on other HEMTT vehicles, but I'm really not sure. I'd like to get $275 for this, or some good trades!
Also up for grabs is a transmission crossmember for a 3L80 in a HMMWV, some miscellaneous mirror parts for the HMMWV, a pair of rear fixed doors in SCAPP camo, and some 60/100 Amp prestolite alternator bracket parts. I'd let any of these go for a reasonable offer.
I'm on the lookout for a camouflage storage rack for the HMMWV, new or like new soft doors (would definitely consider an entire 2-man soft top assembly), Scepter MFC fuel cans and water cans (OD preferred for all), VIC-1 intercom system, and various bits of more modern radio equipment (1985+). If you want something of mine and want to trade for it, feel free to just shoot over any offer of what you had that might go good with my HMMWV!
Wildchild467
59
Milford / Michigan
I'm looking for a left rear hub for an M35A2 Deuce. I'm ok with getting one with a drum as they are easier to deal with as long as its all in good shape.
Gimp - Do you still have the M35A3 seat?
85 USMC M998
17
Monroe Area, MI
Looking for:
PN 12342960 BRACE ASM BUMPER this is the inside brace (see photos below)
PN 12469169 (HUM) PLATE BUMPER REINF
(see photos below)
PN 12338937 Grille, Metal Front, Basic Armor
(see photos below)
M101A1 Wheel/Tire that I could use as a spare
MWMULES
352
DESOTO, KANSAS
I have a few NOS in the box Military Battery chargers with 110V and 24V power cables and Manual $60ea, not for truck batteries just small rechargeable radio, tow sight batteries ect.
If you want one let me know as will only bring a couple.
These are 24V 70W floods $12 ea
camoyj7
19
wonder lake IL
List for Findlay
5 Hmmwv 2 man cargo covers
2 old style slave cables
5 tractor light cables
7 5Ton tire chain falls
4 military air hoses
3pr 3/4 tow bar feet
2 5ton tire choker chain
2 Hmmwv gunner stands
2 Hmmwv pass side seat reinforcement
1 M1114 battery box cover
1 M1151 rear a/c box
1pr M939 heavy front cab mounts for armor or LWS
3 used Hmmwv engine harness
1 used Hmmwv body harness
2 5ton spare tire trolley.
2 new 5ton/deuce lug wrench
1 mt5363 radio mount
1 geared lug wrench
2 used lug wrenchs 5ton/deuce
4 Hmmwv offset antenna mounts
1 new Hmmwv steering column
1 like new Hmmwv steering column
1 Hmmwv oil pan
1 1899 radio mount
3 new Hmmwv rear calipers
1 new solarigizer kit
1 new pulsetech solar charger
2 used Hmmwv TCM's
1 M35 axle u joint
4 Hmmwv splash shield armor
1 Hmmwv battery box cover
2 Hmmwv a2 fans
3 Hmmwv jack kits
3 Hmmwv pioneer kits
More to come.
MWMULES
352
DESOTO, KANSAS
Got off the phone with Kip last night and this year not only will he have a tent set up, he has one of the newer AirBeam Shelters that is 32' x 20'.
So if you need a place to set up your cot send him a PM.
1,827
MAXJEEP
Goshen Ohio
I am looking some parts for my HWWMV M998A1 and will be at Findlay Saturday
- windshield channel for a soft top
- windshield rubber bump stops
- headlight rings
- drivers side seat belt
- turn signal canceling ring
- brake light switch
- may need a start box and temp sensor. I need to figure this out this weekend
I am sure their will be more.
-radio shelf
-cargo decider and brackets for a 2 man
-battery hold down
zebedee
conceptualizer at large
898
Central NY
Bringing:
Transfer lever extensions (for split shiftin' 5 tons).... pre order please.......... $30
ISU/Cadillac container (shelf) brackets, per shelf - 4 pcs ........... $15
20 Ton (made in USA) Bii bottle jack ........... $45
Flight suit - tall (good for 6'4" but tiny waist! - maybe 28/30/32) ...... $10
Will bring if sold:
Med/Heavy towbar - similar to "heavy", non telescoping, without spare pin stowage 'handles' (no feet) ...........$135
Med towbar telescoping leg (not the lunette side) ............. $55
Committed to (so I remember to pack!):
Wrecker/tractor spade (x1 only) M816.........Shirehorse
30 ton jack, slat grille - Shirehorse
Stuff from Carnac to Shirehorse
LOOKING FOR :
Coveralls/flight suit - tall (~6'4") x 34"+ waist
